Thread: Open wing mirror to replace LED unit
Results 1 to 10 of 11
  1. Open wing mirror to replace LED unit
    Aug 2015
    Maidstone, England
    New to forum after taking possession of a MY12 Avant last week.
    Loving the car a lot but I have an intermittent fault in the passenger side wing mirror.
    The LED is extremely dim but still flashes just about, but I get a fault reported on the dash.
    The dealer I've bought it from is sending me a new LED unit for the mirror.
    I've seen a couple of YouTube videos about popping the glass out for older A6's and just wanted to know if anyone had any experience to confirm its for more or less the same for my car?
    I've done repair and replacement work on my cars before, but Audi is all new to me.
    Loving the forum so far.
    Graham
  2. Re: Open wing mirror to replace LED unit
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    Just changed my glass, just oiked it out using piece of flat plastic. If you use a screwdriver or similar remember to put some tape on first to protect the paint.
    1 1 0
  3. Re: Open wing mirror to replace LED unit
    Aug 2015
    Maidstone, England
    Excellent, thanks.
    Thought it might be the same. Once the part turns up I'll give it a go.
  4. Re: Open wing mirror to replace LED unit
    Jan 2010
    Yate UK
    17 Post(s)
    Yes, the glass is relatively simple to prise out, I did mine with a teaspoon.
    The LED unit itself screws on fairly simply, the difficult bit is the black part of the casing underneath the mirror housing which clips in to the top part - the clips are pretty stiff and I broke a couple trying to take mine apart.
    I'm a bit cack handed at that kind of thing so if you are half way competent you'll be fine.
    Now: 2016 C7 2.0TDi BE with Tech Pack, magic parking, ambient lighting
    Previous: 2013 C7 2.0 TDi S Line
    C6 2.0 TDI LE
    A4 2.0 TDI SE
    and an ancient 80 in the olden days...
  5. Re: Open wing mirror to replace LED unit
    Jan 2013
    114 Post(s)
    Prised mine out with a plastic picnic knife, sad but true.
  6. Re: Open wing mirror to replace LED unit
    Aug 2015
    Maidstone, England
    I've finally got the part and I can only get to one of screws and a couple of clips holding it in. The other screw and clips are behind the motor.
    I've tried to take this out but unscrewing the two screws holding it to the housing and wiggling but there is zero movement.
    Turns out getting the glass out was the easy bit.
    Any helpful suggestions would be greatly welcome please.
  7. Re: Open wing mirror to replace LED unit
    Jan 2010
    Yate UK
    17 Post(s)
    I took the whole casing off (as it was smashed up by a passing lorry) - might be the only way to get to all the screws.
    Hard to explain how to get the casing off, when you get all the clips and screws out there was a certain way of hitting it that made it come free - a friendly local dealer showed me the method.
    I have a feeling I resorted to You Tube before I got that far.
    C6 2.0 TDI LE
    A4 2.0 TDI SE
  8. Re: Open wing mirror to replace LED unit
    Aug 2015
    Maidstone, England
    Heh. Looks like it designed well enough not to come off.
    I'll have another play tomorrow.
    YouTube isn't really helping to be honest. Plenty of help for C6 and earlier but not C7.
  9. Re: Open wing mirror to replace LED unit
    Aug 2015
    Maidstone, England
    Well... I managed to do it
    Not quite sure how, just sheer determination and grunt.
    You do have to get the colour coded housing off, and this is done by the two screws at the top on either side, pushing the clips open (managed to snap one) and then just hitting the top outer edge with the open palm of your hand to force it upwards.
    It feels like it might break but the clips holding it inside just give way eventually.
    Unscrew the LED unit and attach the new one, and then push the housing back over making sure all the clips on the underside go in and the two clips are positioned correctly inside at the top where its screwed in before giving it that final push to lock it all together.
    Not something I'd want do again.
  10. Re: Open wing mirror to replace LED unit
    Jan 2010
    Yate UK
    17 Post(s)
    Success!
    I agree, not something you want to do often - the incentive for me was avoiding the £500+ I was quoted for a new mirror.
    C6 2.0 TDI LE
    A4 2.0 TDI SE
  1. How To Remove / replace wing mirror unit on VW Golf MkV 1.6SE
    By deantrappett in forum Golf MK5 - 2004 - 2009
    Last Post: 03-02-2015, 02:28 PM
  2. Led lights wing mirror
    By dufc in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 13-04-2012, 01:16 AM
  3. Question Led wing mirror indicators
    By noonoo63 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-02-2010, 09:04 PM
  4. Wing Mirror LED fail, how do i get to it?
    By scott26 in forum Beetle 2000-
    Last Post: 31-05-2009, 10:12 PM
  5. A4. How d'you replace a wing mirror ?
    By PeterT in forum Audi A4 - Archive Topics
    Last Post: 23-10-2007, 05:10 PM
