Thread: 2007 2.7Tdi Brake disc size?
Results 1 to 9 of 9
  1. 2007 2.7Tdi Brake disc size?
    Jun 2013
    Scotland
    Hi Forum,
    Having a bit of bother finding out the disc size for my 2007 2.7Tdi.
    I am needing front and rear and have already been sent the wrong size and un-vented rears.
    I have tried ECP and they state solid disc for the rear but they are vented.
    Ta,
    Deano.
  2. Re: 2007 2.7Tdi Brake disc size?
    Jul 2013
    76 Post(s)
    You need to check the PR code on the sticker in the boot.
    Your looking for something like 1LT
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: 2007 2.7Tdi Brake disc size?
    May 2014
    Darlington
    78 Post(s)
  4. Re: 2007 2.7Tdi Brake disc size?
    Nov 2012
    Somerset UK
    I found out my disc size by simply using a ruler against the outside of the wheel, the difference between the sizes available is quite visible/noticeable
  5. Re: 2007 2.7Tdi Brake disc size?
    May 2014
    Darlington
    78 Post(s)
    The other problem you may run into is when the last owners upgrade the brakes, so you will have no idea what they have fitted!
  6. Re: 2007 2.7Tdi Brake disc size?
    Jun 2013
    Scotland
    Found out the size guy's.
    They are 347mm on the front and 330mm on the rear and vented all round.
    Standard size for the 2.7 and 3.0 inc the quattro.
  7. Re: 2007 2.7Tdi Brake disc size?
    Sep 2011
    Lurking over a keyboard ...
    Yours must be S-Line?
    IIRC my 3.0 quattro (SE) has 321 / 302 , front vented, rear solid.
    Link:- Some brake data in this post
  8. Re: 2007 2.7Tdi Brake disc size?
    Jun 2013
    Scotland
    It is a Le Mans spec model. Can't see how they should have different sizes between the SE and s-line if they are the same power.
  9. Re: 2007 2.7Tdi Brake disc size?
    Sep 2011
    The size of brakes that the SE comes with are not inadequate its just that the S-Line / Le Mans comes with uprated brakes.
    The 2006 on-line brochure states only apply to 3.2 FSi & 3.0TDi, page 11.
    Audi tends to change what it includes every so often, perhaps the 2.7 TDi due to being a V6 was also included.
    I know for sure what I have is correct for my car as have all PR code data for it, more than what is on the VIN sticker in spare wheel well/service book .
    I cross ref'd codes when fitting discs/pads.
  1. Question A4 brake disc size
    By HAWKS in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-05-2013, 09:06 PM
  2. Question Front brake disc size
    By Tristan77 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-01-2013, 03:17 PM
  3. Question Brake disc size
    By graym78 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-01-2010, 01:46 PM
  4. Brake Disc Size
    By Noddi in forum Alhambra
    Last Post: 22-07-2009, 10:20 PM
  5. A4 brake disc size
    By a4_jim in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-07-2008, 06:57 PM
