Thread: SE seats to Sline seats
Results 1 to 10 of 11
  1. SE seats to Sline seats
    Dec 2005
    Hi All.
    I am thinking about changing my SE trim seats to SLine seats. I have manual seats with only electric lumbar. If I buy exactly the same (with only electric lumbar) SLine trim will this be just plug and play job? Do plugs are the same and will have no errors on dash? Thank you for any help.
  2. Re: SE seats to Sline seats
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    Yes simply replace and job done, If you disconnect battery first and reconnect after fronts have been refitted then airbag light wont need resetting.
  3. Re: SE seats to Sline seats
    Dec 2005
    Ok. Thank you. Is it the same if I would like to change speedometer to colourful as I have only basic black and white? Or it is more complicated. Thank you for help
  4. Re: SE seats to Sline seats
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    Different kettle of dolphins altogether, expensive and not too easy. All for very little. My advise? Don't bother.
    0 2 0
  5. Re: SE seats to Sline seats
    Jul 2013
    Cardiff
    I'd be interested in doing the same - where are your sourcing the s-line seats from? new or second hand? and at what kind of cost?
  6. Re: SE seats to Sline seats
    Oct 2014
    Innsbruck, Austria
    I have changed the speedometer from black and white to colour. It is somehow plug and play.
    Just make sure that the speedometer is the right one. If your car has ACC, buy one for ACC (or from a car that has ACC). If not, buy the one without.
    My car hasn't got ACC and the speedometer was on a car with ACC. I had some troubles to code that option out. I don't know why, all the other coding went smooth.
    You will need to change them at a dealership since all the speedometers have component protection. this can only be activated by them online.
    Note: The ODO will show the km from the new dashboard!!!
  7. Re: SE seats to Sline seats
    Dec 2005
    Quote Originally Posted by Clauuualc View Post
    Hi. you are the first one that did the swap.
    How much did pay for all (part and labour)? and where did you do it? Was it a main dealer or independent garage?
    Thank you for all information. Peter
  8. Re: SE seats to Sline seats
    Apr 2009
    Surrey
    183 Post(s)
    Bear in mind that the S-lIne seats use different leather to the SE seats (Volcana rather than Milano) and also they have a different stitching pattern. You may therefore want to swap the rear seats as well or it will look obvious that the front seats are not original
  9. Re: SE seats to Sline seats
    Dec 2005
    Hi all. Does anyone know if seats from saloon will fit to estate? Please reply as soon as possible. Thank you.
  10. Re: SE seats to Sline seats
    Apr 2009
    Surrey
    183 Post(s)
    Quote Originally Posted by noogman View Post
    It looks like the cushions (9 on linked diagram) are the same but you will need to swap the back parts (2 on the linked diagram)
    AUDI A6/AVANT [A6] (EUROPE) 2013: BODY: 88570. BACKREST, SPLIT
  1. Replacing cloth seats for Leather seats.
    By B5-Passat-1988 in forum Octavia
    Last Post: 23-01-2015, 12:47 PM
  2. 2014 A6 Sline seats..
    By Audi head in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 03-05-2014, 10:33 PM
  3. Standard Seats vs electric adjustment or comfort seats
    By jonclare in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 24-09-2013, 09:54 AM
  4. Sports seats or standard seats ??
    By Andy Grob in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-07-2010, 02:41 PM
  5. a3 2002 suede seats swapped for 1999 leather seats, airbag resistor mod?
    By tonto2k in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 24-07-2009, 01:00 AM
