Thread: Idle Issue with Cable throttle A4 B5 1.8T
  1. Idle Issue with Cable throttle A4 B5 1.8T
    Nov 2008
    Redditch
    My A4 Quattro Sport Avant 1.8T has an annoying idle problem-
    When you back off the throttle the revs go very low for a fraction of a second, then pick up, over rev a bit, go low, pick up and then go to normal idle speed.
    If you blip the throttle the same happens when you release the throttle.
    It's a cable throttle model (1999) AJL engine.
    Throttle cable is free and smooth.
    It seems like the throttle body is sticky or the ECU is taking a while to sort out a stable idle speed.
    Any similar experiences?
    Likely cause?
    I was thinking of stripping the throttle body down and cleaning & lubricating everything then re-assembling...
    Grant
    '99 Audi B5 A4 1.8T Sport Quattro Avant
  2. Re: Idle Issue with Cable throttle A4 B5 1.8T
    Dec 2008
    I know this is an old post, but hopefully my reply will help someone out eventually. I had this exact problem on a 1996 1.8 petrol saloon I used to own. Problem turned out to be on intake side, not sure what exact term was for it but throttle body sounds right. Anyway, several doses of carb cleaner while at high revs cleaned it up and all was well after that. I'd rev the engine by pulling the throttle cable and liberally spray into the intake ( I recall opening up pipe before throttle body, so not spraying in before air filter) to the point where the engine would drop revs and almost die.
  1. Throttle not releasing/idle issue
    By Lee8 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-11-2012, 03:55 PM
  2. Question VR6 throttle cable Part #
    By surge1468 in forum Golf MK3 - 1993 - 1999
    Last Post: 22-02-2012, 02:48 AM
  3. Question Throttle cable adjustment - 1.6 AEE
    By silestanix in forum Golf MK3 - 1993 - 1999
    Last Post: 11-01-2011, 02:38 AM
  4. mk 3 driver throttle cable
    By no1dunc in forum Golf MK3 - 1993 - 1999
    Last Post: 07-10-2010, 05:27 PM
  5. 05 2.0tdi Idle issue & '97 1.8 engine issue
    By dbbear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-08-2009, 02:11 PM
