Thread: Engine Management Light
  1. Engine Management Light
    Sep 2007
    hello.
    my first post... only had the car a week and a half!
    toward the end of my journey home today the little orange engine management light came on. as far as i can tell the car drives and sounds exactly the same...
    after a bit of reading on here it seems its likely to be a fault with the fuel mixture??
    I know you cant tell me more without knowing the code...
    the car is going to a garage tomorrow so i will get the faults read then.
    Just wanted to check that i am ok driving the car with this light on. when starting the car the OK light comes up as normal. am i right in saying that if it was a serious problem the car would 'limp' home rather than drive normally?
    Thanks,
    Chris
  2. Re: Engine Management Light
    BIGBADBORA Guest
    what car are you driving.
  3. Re: Engine Management Light
    Sep 2007
    sorry
    2001 (Y Reg) Audi A3 1.8T - standard car
  4. Re: Engine Management Light
    BIGBADBORA Guest
    the problem may be anything but not serious if the car is driving ok. have the fault codes read and see what shows up. ive seen skoda octavias with the light on and it was no brake lights. audi a4 with a faulty oxygen probe. common faults on audi and vw is the air flow meter. dont know if this helps but let us know after the garage has found the fault.
  5. Re: Engine Management Light
    Sep 2007
    thanks for you help mate
    turned out to be an air leak from one of the pipes around the turbo. the mechanic took the pipes off the turbo and cleaned them up, re-sealed them and so far no more light! fingers crossed
    so your right... can be anything really!
  1. Engine management light on
    By tonyjmoore in forum Polo - Derby - Lupo - Fox
    Last Post: 26-11-2007, 03:08 PM
  2. s6 engine management light
    By monkey boy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 27-09-2007, 10:21 PM
  3. engine management light
    By murtym in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 22-07-2007, 11:18 PM
  4. engine management light
    By johnnynonails in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-01-2007, 04:02 PM
  5. Engine management light came on
    By curiousgeorge in forum Audi A3 - Archive Topics
    Last Post: 05-01-2007, 10:27 PM
