Thread: Oil Sensor Workshop
Results 1 to 10 of 20
  1. Oil Sensor Workshop
    Aug 2007
    Northern Ireland
    Problem solved - thanks guys
    If it aint broke dont fix it, right!?
    Wrong!
    OK I'll set the scene:
    Messing around today trying to read my ECU with a KWP2000 interface... removed fuses 11 and 15 from the fuse box (Instrument cluster)
    Cut a long story short, couldnt read the ecu, put fuses back, cleared the faults with vag-com.
    Find that climatronic wont power up, and "Oil Sensor Workshop" displays on the cluster.
    I take it that the "Oil Sensor Workshop" message is something to do with service interval, the car was serviced 500 miles ago, should I just log in and reset it back?
    Climatronic appears to be totally lifeless, no display at all, and no indicated air temperature on the instrument cluster.
    Any suggestions?
    Yes, this will teach me to mess with something I "thought" I knew something about.
    Last edited by mobitune; 05-10-2007 at 05:55 PM. Reason: Problem solved - thanks guys :)
    52 plate Golf GT TDi
  2. Re: Oil Sensor Workshop
    Canada
    Quote Originally Posted by mobitune View Post
    Wrong!
    Any suggestions?
    I would think that if you know the oils good, then reset it and see if it come on again. It won't hurt its and aid for the driver and as you have chaged the oil then you know were you stand.
  3. Re: Oil Sensor Workshop
    BIGBADBORA Guest
    Quote Originally Posted by onzarob View Post
    oil sensor workshop refers to the oil level sensor in the sump. but god knows what you have done. try resetting it see what happens. i drove for a year with that on the display cos i wouldnt pay for a new sensor. 100 odd quid for a sensor but if u buy a new sump u get the sensor with it for 130. figure that out. a sump for 30, sorry im rabbleing here goodluck on the reset.
  4. Re: Oil Sensor Workshop
    May 2007
    The sensor is not that much to replace, the part cost £56 from vw and about an hour to fit it, plus you will prob want to put new oil in as you have to drain it out, so that you can get the sump off, All the sensor does is tell you when the oil level is getting low and it makes the orange oil can light come on, with the message "check oil level".
  5. Re: Oil Sensor Workshop
    Aug 2007
    Northern Ireland
    Thanks guys,
    Any pointers on this?
    Pete
    <edit>
    Just been out trying to reset service indicator and have discovered that cruise control is no longer working either
  6. Re: Oil Sensor Workshop
    Grant Guest
    Quote Originally Posted by BIGBADBORA View Post
    ours started doing this the other night, however this might make sense as our mk4 is down about 100mm on coil overs and apparently the mrs went over a rock in the road during the day and it bounced under the engine and down the length of the car.
    do you think the shock of a rock smacking off the sump would affect the sensor?
  7. Re: Oil Sensor Workshop
    Oct 2005
    Thanks guys,
    Pete
    <edit>
    Put the diagnostics down and step away from the car! Did you get that sick feeling in your stomach? <chuckles>
    The fuses you removed - why did you remove them? Have you checked they've not blown?
  8. Re: Oil Sensor Workshop
    Aug 2007
    Northern Ireland
    Heh... didn't really get that sinking feeling, because im 99.999% sure its something simple. I did have the sinking feeling yesterday when I thought id fried the ccm (turned out that the drivers door wasnt closed properly hence the central locking not locking) lol
    Fuses:
    Yep, checked today.. Odd though because the climatronic and cruise control are on the same fuse!
    I'll take another look now I think.
  9. Re: Oil Sensor Workshop
    Aug 2007
    Northern Ireland
    Turns out all is stemming from a completely different incident!
    When I removed the fusebox cover I noticed a fuse that hadn't been fitted properly, when I grabbed it with the tool it came out, when I refitted it I plugged it into the socket below where it should've been!
    In other words, Fuse #5 was missing!
    All problems sorted, everything
    Made me realise how bu##ered i'd be if the climatronic failed, had to go into town earlier and was like a baked potato when I got back :-\
    Pete
  10. Re: Oil Sensor Workshop
    Oct 2005
    Fuses:
    That was my next idea!
    Don't just inspect it, take it out and swap it for another one. Sometimes the break is so subtle you miss it.
    EDIT:
    Hahaha, job done - glad you got it sorted!
  1. Oil Sensor Workshop! Warning
    By SW TDi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-06-2016, 11:20 AM
  2. Oil sensor workshop
    By v6dub in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 18-10-2007, 10:27 PM
  3. bora oil sensor workshop light
    By johnyfromdonny in forum Bora - 1998 - 2005
    Last Post: 25-09-2007, 08:36 PM
  4. workshop manual
    By szoke91 in forum 80 - 90
    Last Post: 13-06-2007, 08:06 PM
  5. Workshop Manuals
    By MercieBe in forum Chat - Completely Off Topic
    Last Post: 13-02-2007, 07:44 PM
