Thread: 255/35/19 tyre pressures
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. 255/35/19 tyre pressures
    Jul 2015
    Bridgend Wales
    Hi, conflicting tyre pressures for my tyres. Purchased my A6 last weekend and upgraded my alloys to 19" Blackline. Checked tyre pressures when I got home, and they ranged from 34psi - 38psi. Been online and asked a couple of tyre fitters and contacted local Audi dealer. Dealer stated they were an "odd" fitment, and didn't have the tyre pressures listed, although recommended 32psi for front, and 30psi at back. Others have mentioned 30 in the front and 28 in the back. Any response would be greatly appreciated.
  2. Re: 255/35/19 tyre pressures
    Mar 2015
    Melton Mowbray
    10 Post(s)
    All supported wheel and tyre combos should be on the sticker in the drivers side door.
    My FL BE 2.0 Avant is showing as wanting 36/35 for 19" rims, but show the tyre profile as being 255/40... 255/35R20
    Yours may be different depending on spec of the car, so take a look at what the sticker says.
    Would running a lower profile tyre than suggested mess up the speedo and odometer, as you will be travelling less distance per revolution?
  3. Re: 255/35/19 tyre pressures
    Jul 2015
    Quote Originally Posted by GrolschUK View Post
    20" tyres on 19" rims would have very interesting pressures!
  4. Re: 255/35/19 tyre pressures
    Mar 2015
    Melton Mowbray
    10 Post(s)
    Quote Originally Posted by isleaiw View Post
    I Probably could have worded that a bit better
    I've got 255/40 on 19"
    His 255/35 is recommended 20" rims on the pressure sticker, and thus putting that profile on a 19" rim is going to mess things up a little.
  5. Re: 255/35/19 tyre pressures
    Mar 2015
    Melton Mowbray
    10 Post(s)
    Being quite sad (and also interested in the affect of this)
    Allowing for slightly iffy maths skills
    For every 10,000 miles on the clock, the car would have only travelled 9,600 if using /35 rather than /40 on 19's
    And sat at <cough> 70 on the motorway, you will only actually be doing 67
  6. Re: 255/35/19 tyre pressures
    Nov 2012
    Somerset UK
    Doesn't the engine size and whether saloon or estate play a factor since a 3.0 lump weighs significantly more than a 2.0 and a 5 door more than a 4?
    May be useful if you actually state this...or ideally put your car spec (year/variant/engine) in your signature strip
  7. Re: 255/35/19 tyre pressures
    Jul 2015
    Bridgend Wales
    Quote Originally Posted by MarkTM View Post
    Apologies if I have not given enough information. It is a 2013 2.0 TDI 177 saloon. As I have already explained, main ******* stated he has not got tyre pressures for my tyres as they are an odd size.
    Also, the sticker in the side of the drivers door does not give 255/35/19 tyre pressure.
  8. Re: 255/35/19 tyre pressures
    Mar 2014
    United Kingdom
    33 Post(s)
    Quote Originally Posted by gman11 View Post
    As far as I can see, that size rim should be fitted with a 255/40/19" tyre. That would explain why the dealer says that they don't have a recommended pressure.
  9. Re: 255/35/19 tyre pressures
    Jul 2015
    Bridgend Wales
    Quote Originally Posted by wildbore View Post
    These are the dimensions of each rim......... PCD - 5x112
    size- -19x8.5
    offset/ET - 35
    centre bore - 66.45
    I have tried gaining the suitable size of tyre to fit these dimensions online, unfortunately have come up so far with a big zero. I wonder if there is someone more technically minded on the forum able to shed some light?
  10. Re: 255/35/19 tyre pressures
    Nov 2012
    Somerset UK
    Am assuming that the tyres are Extra Load as (IIRC) they have to be for insurance purposes due to the weight of the car.
    Googling the tyre size brings this up on an A5 forum:
    19" Y tyre pressure - Audi A5 Forum & Audi S5 Forum
  1. Question What tyre pressure for 255/40/19 on 3.0 TDI?
    By ChrisCi in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-08-2014, 03:06 PM
  2. Tyre's. 255/35/19
    By denpot in forum Wheels and Tyres
    Last Post: 09-04-2013, 10:40 PM
  3. Question Tyre Help - What 255/35 19 To Fit?
    By Bristle Hound in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-04-2012, 04:50 PM
  4. Tyre pressures & Tyre wear?
    By derekm in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-03-2010, 09:22 PM
  5. Tyre pressures and tyre pressure warning light
    By Foxtrot Oscar in forum Golf MK6 - 2009 - 2013
    Last Post: 26-07-2009, 07:14 PM
