Thread: VW BXE Engine problems
  1. VW BXE Engine problems
    I,ve just acquired a Passat TDI Estate with the BXE engine that has had the very common Conrod failure. It hasnt put the conrod through the side of the block but caused some minor damage to crankshaft. The bearing journal was unaffected by this but unfortunately the previous owner removed parts 6 months ago and there is now surface rust on just half of the bearing journal. Ist question is whether this is terminal or not, and if I were to replace engine with a BKC engine, what would need recoding.
  2. Re: VW BXE Engine problems
    Aug 2011
    Meath
    Engine will fit no problem
  3. Re: VW BXE Engine problems
    Thanks for the reply. Would I need to get recoded.
  4. Re: VW BXE Engine problems
    Aug 2011
    Meath
    Depends on what you swap over from your engine. Maybe injectors can't think of anything else
  5. Re: VW BXE Engine problems
    SE London
    Quote Originally Posted by yorky19640 View Post
    You would also have to swap over the ECU from the doner BXE vehicle to yours AFAIK
    So, having done that your Immoboliser, which uses information from the ECU, would have to be re-coded unless you can get ahold of the IMMO PCB from the doner vehicle that's at the bottom of the steering column, at least
    Your mileometer uses stored information in ECU. So that would have to be re-coded to that stored in the replacement. There's been talk of VAG Commander being able to do this but I've not personally seen it done.
    I don't know how your autobox's ECU would react to having a BKC engine instead of a BXE (both 103bhp @ 4,000rpm stock)
    Check whether the same module's used for both?
  6. Re: VW BXE Engine problems
    Aug 2011
    Meath
    When I do an engine change it's almost always bare or even a short motor, that way you're using all your own sensors and electronics. The mechanicals are just bolt on
  1. Please Help Touran 2006 BXE clutch problems
    By xouser8334 in forum Touran - Sharan - Caravelle
    Last Post: 24-10-2016, 06:49 AM
  2. Just bought a bxe engine?
    By nemerkh in forum Golf MK5 - 2004 - 2009
    Last Post: 10-09-2014, 09:49 PM
  3. PD 1.9 BXE Con Ro Problems
    By jim_tdi in forum Golf MK5 - 2004 - 2009
    Last Post: 22-07-2014, 11:12 AM
  4. BXE Engine Mounts
    By TDiBoraSam in forum Jetta MK3 - 2005 - 2013
    Last Post: 24-06-2013, 07:52 PM
  5. Difference between BKC and BXE engine?
    By TDiBoraSam in forum Golf MK5 - 2004 - 2009
    Last Post: 15-06-2012, 02:25 PM
