Thread: TT 3.2 misfiring help
  1. TT 3.2 misfiring help
    Jan 2009
    My 3.2 is poorly, it struggles to start when it does its missing badly.
    Ive scanned it vagcom and it showed these errors:
    Address 01: Engine Labels: 022-906-032-BDB.lbl
    Part No SW: 022 906 032 HJ HW: 022 906 032 GP
    Component: MOTRONIC ME7.1.1 0672
    Revision: --H02--- Serial number: AUX7Z0F8FNK0MW
    Coding: 0000178
    Shop #: WSC 01236 785 00200
    VCID: 5AB18CB19504589
    6 Faults Found:
    000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
    P0036 - 004 - Malfunction / Open Circuit
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 0
    Fault Frequency: 7
    Mileage: 123076 km
    Time Indication: 0
    Date: 2015.03.03
    Time: 00:04:17
    Freeze Frame:
    RPM: 1050 /min
    Load: 19.6 %
    Speed: 0.0 km/h
    Temperature: 19.0°C
    Temperature: 22.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 13.716 V
    000049 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
    P0031 - 002 - Short to Ground
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 123076 km
    Time Indication: 0
    Date: 2015.03.03
    Time: 00:04:18
    Freeze Frame:
    RPM: 1222 /min
    Load: 16.1 %
    Speed: 0.0 km/h
    Temperature: 19.0°C
    Temperature: 22.0°C
    Voltage: 13.843 V
    000768 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 -
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 123076 km
    Time Indication: 0
    Date: 2015.03.03
    Time: 00:04:21
    Freeze Frame:
    RPM: 1321 /min
    Load: 15.7 %
    Speed: 0.0 km/h
    Temperature: 19.0°C
    Temperature: 22.0°C
    Voltage: 13.970 V
    000774 - Cylinder 6
    P0306 - 001 - Misfire Detected
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    1111 Mileage: 123076 km
    Time Indication: 0
    Date: 2015.03.03
    Time: 00:04:21
    Freeze Frame:
    RPM: 1321 /min
    Load: 15.7 %
    Speed: 0.0 km/h
    Temperature: 19.0°C
    Temperature: 22.0°C
    Voltage: 13.970 V
    000772 - Cylinder 4
    P0304 - 001 - Misfire Detected
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 123076 km
    Time Indication: 0
    Date: 2015.03.03
    Time: 00:04:21
    Freeze Frame:
    RPM: 1321 /min
    Load: 15.7 %
    Speed: 0.0 km/h
    Temperature: 19.0°C
    Temperature: 22.0°C
    Voltage: 13.970 V
    000773 - Cylinder 5
    P0305 - 001 - Misfire Detected
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 123076 km
    Time Indication: 0
    Date: 2015.03.03
    Time: 00:04:44
    Freeze Frame:
    RPM: 1520 /min
    Load: 17.2 %
    Speed: 0.0 km/h
    Temperature: 20.0°C
    Temperature: 22.0°C
    Voltage: 14.097 V
    I took the plugs out on 4,5,6 also and they were very black so i swapped them over to 1,2,3 but that didnt solve it either.
    Ive changed the coil packs in 4,5,6 and ive bought the pre cat lambda sensor today which ive fitted but no change.
    Ive checked the measurements for the cam chain and its fine plus no cam shaft errors on vagcom.
    im slowly pulling my hair out!
  2. Re: TT 3.2 misfiring help
    May 2015
    ohio
    Normally when u have 3 misfires like 4,5,6, ends up being something else throwing out those codes, which you obviously discovered. I recently had the same issue in my A6 2.7 tt and ended up being a very small paper thin tear in throttle body boot by clamp, and egt sensor. I popped the cover off of the passenger side on mine it was the brown one, black is driver's side. And looking very closely with a magnifying glass i could see there was a soldering lead not making complete contact. Re soldiered the connection and replaced throttle body boot and fix my issues . Double check sparkplug gap, double check for vacuum leaks, but you could definitely have an 02 sensor that needs replacing, just slight chance other things are causing that code,but iv seen many cars run like crap just from 02 sensors.
  1. A4 Still misfiring....
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-04-2014, 12:17 AM
  2. misfiring on a4
    By a4constu in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-07-2013, 10:04 AM
  3. Misfiring 1.8T A3
    By drt49786 in forum Audi A3 - Archive Topics
    Last Post: 02-09-2008, 03:52 PM
  4. Misfiring
    By dstroi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-08-2008, 02:42 PM
  5. 98 s4 misfiring...
    By the lemster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-12-2007, 03:08 PM
