Thread: Boot lock won't engage
  1. Boot lock won't engage
    The boot shuts but won't stay shut. Any ideas?
    John
    (MK1 Sharan, S Reg)
  2. Re: Boot lock won't engage
    Jul 2006
    scunthorpe
    has the car got central locking ? try putting a screwdriver in the latch hole on the boot door (which is visible when the the boot is open )if the lock is ok it will grab the screwdriver if it doesn't it could be the lock motor has broken, when you open the boot can you hear a motor when you lift the handle?if not the lock motor has broken or a link has come off either way you will have to remove the plastic panel from the boot door to asses what has happened, or the latch wants adjusting on the boot floor slacken off the 2 screws (do not remove them) adjust the latch then retighten hope this helps
  3. Re: Boot lock won't engage
    Aug 2006
    I am assuming that you dont have a locking problem, but it culd be that the latch into which the latch in the boot door locks into could be out of line with the door latch. You might find that it has moved (probably) forwards meaning that the door is not engaing properly?
  4. Re: Boot lock won't engage
    Thanks for your answers. I took the panel and lock mechanism out and re-lubicated it and it seems to be fine. I guess the grease had dried out or some grit or rubbish had got into the mechanism. It did play up last year but seemed cured by WD-40. I wonder if that actually made it worse being too thin a lubricant and have used thick grease this time.
    Thanks again
    John
  1. Boot lock sensor
    By leontdi90 in forum Leon
    Last Post: 27-07-2007, 11:15 PM
  2. Boot Lock
    By lennymfo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-06-2007, 12:07 PM
  3. Boot Won't Lock
    By new to vw in forum Passat - Archive Topics
    Last Post: 20-03-2007, 06:18 PM
  4. Boot lock not locking
    By Nebooaw in forum Passat - Archive Topics
    Last Post: 13-03-2007, 11:05 AM
  5. Passat Boot Lock doesn`t Lock
    By Graeme H in forum Passat - Archive Topics
    Last Post: 10-03-2006, 11:34 AM
