Thread: HELP boost leak?
Results 1 to 10 of 11
  1. HELP boost leak?
    Jul 2008
    I have a 2.0 TDI Quattro 170 A3 that has been remapped and DPF removed, EGR blanked. should be around the 215bhp mark. The remap (was) absolutely fantastic, it completely transformed the car, even a dab of throttle would shunt me forward and the torque was amazing, so good infact the clutch used to slip in 4th gear (replacing clutch in near future).
    Recently however when giving it a bit of beans the car no longer feels as quick as it did, seems like theres not much boost there. The turbo was inspected when the DPF delete was carried out and it was OK, no oil leakage/shaft play, there doesn't seem to be anything untoward with it.
    I scanned the vehicle with VCDS and there are no fault codes. It feels like there is a hell of a LOT more power to give but its just not happening. Also the clutch no longer slips leading me to believe it's definitely not as powerful as before.
    • Off the top of my head I'm thinking boost/vacuum hoses
    • Possibly the fuel filter
    • MAF sensor
    • Could it be possible clutch is completely knackered and engine is limiting torque as a result?
    I have VCDS/VAG-COM if anyone could let me know which blocks I should be measuring I can post a log.
    Appreciate any guidance as the lack of power is really doing my nut in.
  2. Re: HELP boost leak?
    Nov 2009
    46 Post(s)
    Get it on a smoke test, it will highlight any air leaks.
  3. Re: HELP boost leak?
    Jul 2015
    south africa
    Sounds like the clutch has died completely mate.
    Sent from my GT-S5280 using Tapatalk
  4. Re: HELP boost leak?
    Jul 2008
    Quote Originally Posted by doctordubs View Post
    If clutch had died wouldnt it be slipping all over the place? Seems to be slipping less than before but literally zero power
  5. Re: HELP boost leak?
    Jul 2015
    south africa
    Hmmmm. No fault codes? Do u hear any odd noises under acceleration? Like a loud hiss?
  6. Re: HELP boost leak?
    Jul 2008
    No fault codes mate. At low revs turbo can be heard spooling up but 2000rpm+ you cant really hear it. With window down it sounds like whoosh/air rushing, revs go up but speed doesnt go up as much as it should. Gonna get it on a ramp and try get hoses inspected. Failing that its either the turbo or clutch :/ turbo isnt making any strange noises and theres no excessive oil usage blue smoke.
  7. Re: HELP boost leak?
    Jul 2015
    south africa
    Cool man. Hope its an easy fix. Wats the mileage like on your car? It may well be the turbo that's dying, or you just got used to the power real quick lol!! Keep in touch
  8. Re: HELP boost leak?
    Jul 2008
    120k but i had the turbo inspected 1k ago and was in good condition unless its worsened a lot. I thought i may have got used to the power at first but i used to get thrown back in my seat accelerating now theres nothing lol... its depressing.
    Will post my findings once its been on a ramp. Heres hoping its not the turbo.
    Already needs a new cambelt, bloody money pit lol.
  9. Re: HELP boost leak?
    Jul 2015
    south africa
    Lol atleast cambelt intervals are relatively far apart
  10. Re: HELP boost leak?
    Jul 2008
    Had the car up on the ramp, intercooler pipes were absolutely caked in oil and there were no splits, heart sunk as we checked the turbocharger out, there was play in the shaft so its safe to say the turbo is gone, now trying to source a new one.
  1. Please Help constant full boost!!! boost leak? MAP sensor?
    By boratdi150 in forum Bora - 1998 - 2005
    Last Post: 21-11-2017, 09:56 PM
  2. Question boost leak or were boost leak is if it is a leak
    By teddy2k5 in forum Golf MK5 - 2004 - 2009
    Last Post: 20-02-2011, 10:30 PM
  3. Audi A4 1.9 TDI (110) Oil leak and Possible boost leak?
    By officialuk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-02-2011, 10:45 AM
  4. 1.9TDI Boost Leak!
    By benjie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-03-2010, 11:41 PM
  5. Boost Leak?
    By FOOTSY in forum Polo - Derby - Lupo - Fox
    Last Post: 17-01-2008, 10:22 PM
