Thread: timing belt 1.8T AEB
  1. timing belt 1.8T AEB
    May 2015
    Norway
    hi ! what is the diffrence between the 150 tooth and 153 tooth timing belt ? The 150 tooth is marked with 4B2 and both with 1.8T AEB.
    pics of the kits:
  2. Re: timing belt 1.8T AEB
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Different tensioners by look of it, maybe slightly bigger diameter on 153 tooth tensioner.
  3. Re: timing belt 1.8T AEB
    133 Post(s)
    1993 Post(s)
    A 2000 ish A6 with an AEB uses kit number 058 198 119 which is 153 tooth Cross references like the SKF VKMA 01008, INA 530 0069 10, Febi 24723, Dayco KTB404, Conti CT919K2, Gates K015492XS. In most kits, the damper 058 109 479 B is not included
  4. Re: timing belt 1.8T AEB
    May 2015
    Norway
    thanks ! i have now ordered the 153 kit. do you have the torque specs for this job with water pump ?
    Sent fra min GT-I9505 via Tapatalk
  1. Replies: 4
    Last Post: 29-04-2014, 04:47 PM
  2. Cam belt kit 058 198 479 A is this correct for 1.8T aeb?
    By rhencullen1989 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-07-2010, 09:40 PM
  3. Passat Timing belt change: 1998 1.8 20v Turbo AEB saloon
    By poosnip in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-06-2010, 03:43 PM
  4. Question 2006 1.6 FSI SE - Timing Belt or Timing Chain?
    By wddonalds in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2010, 05:44 PM
  5. Changing the timing belt and drive belt on Audi A6
    By Robbromilow in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-09-2009, 08:00 PM
