Thread: RNS 510 no sound and stuck in German
Results 1 to 10 of 11
  1. RNS 510 no sound and stuck in German
    Dec 2007
    Does anyone know why my Golf radio display suddenly changed to German language and the radio will not play any sound. The phone also will dial but no sound out of the speakers. The navigation appears to be ok and displays the correct position. I have tried running the disc into it which took about an hour but made no difference. It is showing SW version 3980. Can anyone help please?
  2. Re: RNS 510 no sound and stuck in German
    Jul 2015
    glasgow
    That's a strange one was the battery flat at some point? Did you jump start anyone for a cause in voltage drop? Am only asking as I have seen this happen b4 and the radio went to factory settings as if it had been just plugged in
  3. Re: RNS 510 no sound and stuck in German
    Dec 2007
    No the battery didn't go flat it just happened on start up. I have tried disconnecting the battery but it made no difference. I can find the language selection in the menu but it just seems to jam when you select English. I have messed with coding trying to get power fold mirrors to work (not fully working yet) and fitted a genuine phone module but it was ok for a while after.
  4. Re: RNS 510 no sound and stuck in German
    Dec 2007
    The dealer upgraded the software which fixed it. Don't know why it happened though? Thanks to South Hereford VW
  5. Re: RNS 510 no sound and stuck in German
    Dec 2010
    Worcs, UK
    If you're going VW Hereford let me know in case you have issues again. I have VCP and VCDS so can help with the majority of electronics issues on the mk6.
  6. Re: RNS 510 no sound and stuck in German
    Feb 2021
    Leeds
    Hi I'm having same trouble with my golf gtd not sure what to do
    0 0 1
  7. Re: RNS 510 no sound and stuck in German
    Feb 2021
    Leeds
    Hi I'm having same problem with my golf gtd not sure what to do
  8. Re: RNS 510 no sound and stuck in German
    Dec 2007
    Hi Julie. It’s been over five years now and it’s still working fine. Did you do anything you think might have caused it? It looks like you’ll have to go to a dealer to see if they can help!
  9. Re: RNS 510 no sound and stuck in German
    Feb 2021
    Leeds
    Few weeks ago had to charge battery but been working fine it's so annoying will it cost loads thanks for you're reply
  10. Re: RNS 510 no sound and stuck in German
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Quote Originally Posted by Julie37 View Post
    The first thing to do is look at your posts in this thread?
    You have posted the same text twice.
    Put your car spec in your signature.
    Is this an OEM RNS 510? Check the language settings.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  1. CC Rline Tdi - views plus RNS 315 v RNS 510
    By mkenn in forum Passat CC
    Last Post: 10-01-2014, 11:18 PM
  2. Question Is RNS-315 to RNS-510 upgrade worth it ?
    By LazLon in forum Tiguan
    Last Post: 03-11-2013, 07:35 PM
  3. RCD 510 v RNS 510
    By Boblell in forum Golf MK6 - 2009 - 2013
    Last Post: 05-07-2013, 03:00 PM
  4. RNS-315 to RNS-510
    By neilsafc in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 19-07-2011, 10:48 AM
  5. audi sat nav stuck in german
    By scone888 in forum In Car Entertainment
    Last Post: 14-12-2008, 11:09 AM
