Thread: 00778 - Steering Angle Sensor (G85)
Results 1 to 10 of 10
  1. 00778 - Steering Angle Sensor (G85)
    Nov 2008
    hi, my sons battery drained whilst on holiday, charged up and now it's showing 00778- steering angle sensor (g85) any ideas ?
    56 plate 1.9 tdi golf
    2008 Audi A6 2.0 tdi s line avant. BRE engine. 19" le mans alloys, bluetooth, sat nav,full leather
  2. Re: 00778 - Steering Angle Sensor (G85)
    Up North
    Drive car around the block and make sure you go lock to lock several times. A flat battery throws up loads of code issues but unless there was something wrong before they usually resolve without problem.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  3. Re: 00778 - Steering Angle Sensor (G85)
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Hi , agree with Teflon, flat or low battery throws up loads, even if you've charged the battery it might be on its way out and not holding full charge. A decent battery should hold charge while he was on few weeks hols.
  4. Re: 00778 - Steering Angle Sensor (G85)
    Dec 2016
    Pitesti
    Sorry to bring up a quite old thread, i as well, have a problem with G85.
    I will try to be as short and to the point as possible.
    At first these errors:
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0104
    014 - Defective - Intermittent
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K1 909 144 H
    They were cleared and didn't show up until today.
    The one on ABS was cleared but not the one on Steereing Assist.
    I tried to do a basic settings on G85, from ABS Brakes module, tutorial from Ross-Tech here but when i hit Go!, it didn't work, the error was Group 060 Not Available.
    Anyway something happened, because now i get these errors, that won't clear:
    02546 - Steering Limit Stop
    005 - No or Incorrect Basic Setting / Adaptation
    000 - -
    Freeze Frame:
    On ABS still no error.
    I went to 44 Steering Assist, Adaptation, but it couldn't read G85, it said Error group 090 Not Available.
    I went several times on Measuring Blocks on ABS Brakes, and only 2 of 6 times it was reading the real time steering wheel angle, the other 4 times, the value was stuck to 0.
    All this time, the power steering is lid yellow on my cluster and the steering wheel is hard to turn, the power steering isn't working.
    Is the Sensor for Steering Angle (G85) faulty and should i change it?
    I've read similar threads, but they didn't help me.
    Please tell me what should i do next, thank you for your time.
    Regards,
    Last edited by lvi935; 13-12-2016 at 07:58 PM. Reason: corrected wrong word, green -> yellow
  5. Re: 00778 - Steering Angle Sensor (G85)
    Dec 2014
    Bedford
    42 Post(s)
    Have you started it up. Turned steering wheel all the way to left and hold then all the way to the right and hold and then turned to straight ahead then drive in the straight position and the light should clear?
    Sent from my SM-G900F using Tapatalk
  6. Re: 00778 - Steering Angle Sensor (G85)
    Dec 2016
    Pitesti
    Forgot to say that i also tried that, 10 seconds each maximum position on the left and on the right and still nothing...
    Golf MK5 1.9 BKC 2005
  7. Re: 00778 - Steering Angle Sensor (G85)
    Dec 2014
    Bedford
    42 Post(s)
    Sometimes they need longer. Driving in the straight ahead position. Iirc upto 30 km h. Bit strange it went down with the battery. I would take it to a specialist. Before rushing in replacing g85.
  8. Re: 00778 - Steering Angle Sensor (G85)
    135 Post(s)
    2038 Post(s)
    Normally it clears after about 1/4 mile on my usual test run which is two hard rights and two hard lefts.
  9. 00778 - Steering Angle Sensor (G85)
    Dec 2016
    Pitesti
    i have finally managed to get it working.
    drove about 10 meters in straight line, stopped, one turn of the wheel to the left, straight the wheel, one turn to the right and again straight, drove another 10 meters, full turn of the wheel to the left, then full turn on the right.
    After that, when i got the wheel straight, the power steering started working and the light in my dash went off.
    The night all started, it was cold outside, could this happen because of a poor battery? I know that the power steering is among the greatest consumers on a car.
    Thank you for your replies, have a nice day!
  10. Re: 00778 - Steering Angle Sensor (G85)
    135 Post(s)
    2038 Post(s)
    Even putting a PQ35 platform car on the lift with the ignition on can bring on the EPAS light, it is standard practice for mechanics to road test a car to solve things like this as it would upset a customer if you left it for them to do.
  1. can you damage the g85 steering angle sensor on a4 b8 after fitting new rack
    By dazbo1972 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-11-2015, 09:15 PM
  2. A3 G85 implausible 00778 steering angle sensor
    By Demo8Dan in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-02-2015, 11:12 AM
  3. G85 fault Steering angle Sensor
    By Pamchico in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-01-2012, 07:51 AM
  4. How to program a replacement ABS Controller & Setup G85 Steering Control Sensor???
    By Tecnic91687 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-01-2012, 10:56 PM
  5. steering angle sensor
    By wozbwfc in forum Bora - 1998 - 2005
    Last Post: 06-02-2011, 06:04 PM
