Thread: Belt Fan Running
  1. Belt Fan Running
    Sep 2007
    Hi, looking for some advice. The belt driven fan on my passat 55 plate tdi 130 seems to run alot of the time. Is this normal even up here in chilly Scotland??
  2. Re: Belt Fan Running
    Aug 2007
    HI There, I think you are referring to the belt driven Viscous Fan. With the
    engine switched off the fan should be easy to turn, if yes then the viscous
    coupling is ok. It should run all the time.
    The electric fan comes in when extra cooling is required.
  3. Re: Belt Fan Running
    Sep 2007
    Thanks very much. Just wanted to make sure it was meant to run all the time.
  1. Running on Veg Oil?
    By L90OOK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-06-2008, 10:03 AM
  2. Cam belt timing belt tip , general
    By Conradvw in forum Archive posts
    Last Post: 11-01-2007, 04:29 PM
  3. timing belt/ cam belt change
    By jonoallen in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-11-2006, 01:24 PM
  4. gti iii 2.0 8v running probs
    By stubbsy in forum Archive posts
    Last Post: 28-09-2006, 10:49 PM
  5. Running like a pig!
    By sunmotors in forum Archive posts
    Last Post: 01-04-2006, 05:06 PM
