Thread: passat 2007 2.0 diesel smoking misfire problem
Hybrid View
  1. passat 2007 2.0 diesel smoking misfire problem
    Feb 2012
    kent
    Can anyone help here
    ive got a 2007 passat diesel its had new low pressure fuel pump new turbo all injectors are ok new harness from VW new fuel filter oil/ filter
    The car misfires and chucks out diesel smoke
    The oil was contaminated with diesel hence the oil change but still misfires and smokes alot
    has anyone had similar
    Thanks in advance
  2. Re: passat 2007 2.0 diesel smoking misfire problem
    Sep 2008
    SE London
    Worth getting a VCDS Autoscan to see what error codes are stored, then clear them, then do a fresh scan to see what's current
    What town? Im in SE London near to Sun in the Sands roundabout off the A102 south of Blackwall Tunnel
    What engine code? What miles? Have you had your DPF icon light up apart from at IGN switch on?
  3. Re: passat 2007 2.0 diesel smoking misfire problem
    Norfolk
    Has timing belt been checked?
    Has it had a remap in the past?
  1. 2007 Passat 140 PD slight misfire under load
    By shropslad in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-06-2015, 11:40 PM
  2. Question 130bhp Passat misfire problem
    By Jasonmac87 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-12-2014, 11:41 PM
  3. Question P0301 Cylinder 1 Misfire - Golf Mk5 2007 Diesel DSG 1.9 Turbo
    By jawwadsyed in forum Golf MK5 - 2004 - 2009
    Last Post: 12-03-2014, 07:50 PM
  4. Please Help passat 2007 dsg sport diesel judder when driving
    By regiannoEG in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-05-2011, 01:10 AM
  5. vw passat 1,9tdi pd smoking problem
    By audi_rs2 in forum Chat - Anything with wheels
    Last Post: 17-12-2008, 11:43 AM
