Thread: VW Sharan Carat 1.9 tdi. How to replace Air Con pressure sensor
  1. VW Sharan Carat 1.9 tdi. How to replace Air Con pressure sensor
    Dec 2008
    Good evening every one,
    been reading this forum for years, and learnt a lot, but now need some help.
    I need to replace the G65 pressure sensor on my wife's Sharan and am not sure which body parts to remove to get access.
    I can take headlights out, front bumpers off and wheel arch liners off, done all those before.
    But what is the minimum I need to remove to change faulty pressure switch.
    Hoping some one can help me.
    Thanks in anticipation.
  2. Re: VW Sharan Carat 1.9 tdi. How to replace Air Con pressure sensor
    Dec 2008
    This is odd ,because I'm going to answer my own question.
    I had a spare hour today so bit the bullet and had a go.
    Quite simple really.
    Remove drivers side front wheel,
    remove wheel arch lining , approximately 15 screws and sitting there behind the liner is the pressure switch. Loosen the old switch off with a 17 mm spanner, disconnect 3wire plug and screw on new sensor, don't forget the new seal as there is not one with the new sensor.
    Fire up the cars air con and watch the interior temperature drop.
    Hope this helps someone.
    Sent from my Elephone P3000S using Tapatalk
    1 1 0
  1. G65 air con High Pressure Sensor - vw part number?
    By greg123 in forum Golf MK5 - 2004 - 2009
    Last Post: 07-07-2018, 11:19 AM
  2. Question Air Con High Pressure Sensor (G65) Location
    By dragondownsouth in forum A8 - S8 - V8
    Last Post: 30-06-2015, 06:52 PM
  3. Replies: 3
    Last Post: 21-07-2013, 12:59 PM
  4. Replace High-Pressure Sensor/Thrust sensor G65)
    By jrabkid in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-06-2013, 04:15 PM
  5. Question Polo 2002 1.4 TDi Air Con Pressure Switch/Water Ingress at rear
    By asheen in forum Polo - Derby - Lupo - Fox
    Last Post: 19-07-2012, 01:29 PM
