Thread: Driveshaft gaiters split
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. Driveshaft gaiters split
    Apr 2011
    Blackburn, UK
    I have splits in both driveshaft outer CV gaiters. Car is a 2004 Golf Mk5 GTTdi and the MOT is due. There is no knocking from driveshafts so I don't suspect the joints to have failed but if it fails MOT on these two items, can these gaitors be replaced without having to buy complete new driveshafts? If so, how much time and cost price should I be looking at for VW to change?
  2. Re: Driveshaft gaiters split
    Aug 2011
    Meath
    It will fail the MOT if the boots are damaged. They cost maybe 15 each and take about 2 hours to do both. A good indie will be half the price of a VW garage
    0 2 0
  3. Re: Driveshaft gaiters split
    Apr 2015
    Damascus, Syria
    Even if it was not due an MOT,,,split gaiters will allow water and God knows what else into the CV ball cage itself, with predictable consequences,, IE new CV joints.
    1 2 0
  4. Re: Driveshaft gaiters split
    134 Post(s)
    2007 Post(s)
    The best boots are the genuine Hytrel polyester elastomer versions, VAG part number 1K0 498 203 A which are £24.89 genuine. These do require special clamp setting grips to be able to set the grip correctly so as it is not too lose that it leaks or so tight it splits the plastic. We sell the Febi version of these kits for £17.36 and they are indistinguishable from genuine.
    1 2 0
  5. Re: Driveshaft gaiters split
    Pembrokeshire
    22 Post(s)
    or fit universal stretchy boots for a fiver each, held on with zip ties. get you through the mot and go again in 6 months, but they do save a few quid...
    0 2 0
  6. Re: Driveshaft gaiters split
    134 Post(s)
    2007 Post(s)
    1 3 0
  7. Re: Driveshaft gaiters split
    Aug 2011
    Meath
    Or, the OP could save even more time and money by buying a universal split boot and just glue it on
    0 2 0
  8. Re: Driveshaft gaiters split
    134 Post(s)
    2007 Post(s)
    Quote Originally Posted by Doctle Odd View Post
    1 3 0
  9. Re: Driveshaft gaiters split
    Pembrokeshire
    22 Post(s)
    tester cannot fail them if he can't see they are split, so something wrapped round them, like an old inner tube or carrier bag will do. a good tip for split balljoint boots is a big dollop of grease smeared round them, or fill the split with instant gasket...
    0 3 0
  10. Re: Driveshaft gaiters split
    134 Post(s)
    2007 Post(s)
    You and me are going to fall out....
    1 2 0
  1. Question Should there be a split in the driveshaft rubber surround (see pic)
    By geoff eeles in forum Golf MK4 - 1999 - 2004
    Last Post: 23-10-2012, 08:39 AM
  2. CV Gaiters
    By Inspector Beetle in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-07-2012, 11:29 PM
  3. gear gaiters
    By lobs84 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 03-01-2009, 11:23 AM
  4. oil covered gaiters behind front hubs
    By aa303 in forum Golf MK3 - 1993 - 1999
    Last Post: 18-05-2008, 08:03 PM
  5. For gaiters sake!
    By vwgolfmk416 in forum Golf MK4 - 1999 - 2004
    Last Post: 18-04-2008, 05:10 PM
