Thread: Removing the key doesn't switch off electrics (intermittent)
  1. Removing the key doesn't switch off electrics (intermittent)
    Jun 2007
    Lymington, Hants
    Hi all,
    I have an intermittent fault (I've actually had it for about 6 years now but it's becoming more annoying!) Sometimes when I switch off the engine and pull the key out, the car doesn't recognise it's been removed. Symptoms of this are MMI stays on, steering lock doesn't engage (no big clunk) and the remote locking doesn't work.
    I've done a search, and this seems to be a problem others have encountered, but there's no explanation fo how to resolve. This thread "remove key and ignition still on" - J519 defective be the source? suggest it's a switch behind the barrel, which would sound correct, and even suggests part number 4B0 905 849.
    It's a 2.0 TDi manual SE. Any suggestions on what it's likely to be, and how to fix it (I'm hoping it's simply pull the dash apart, replace switch, put back together) would be appreciated.
  2. Re: Removing the key doesn't switch off electrics (intermittent)
    Mar 2015
    Lytham st Anne's
    Did anybody get a fix for this I have the same problem now cheers
  3. Re: Removing the key doesn't switch off electrics (intermittent)
    Aug 2012
    Aberdeenshire
    No fix, but i also have this problem.
    I believe the electro-mechanical part of the lock module wears so it doesn't make the contact.
    The mechanical part (lock) is fine
    I understand the fix is to change the module -but I'm living with it at the moment as it isn't causing much bother.
    If I ever get around to dismantling one I'll post it here
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon SOLD
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue SOLD
    2006 A6 Allroad 3.0 TDi, Blue - getting ready to get rid of
    2008 A5 3.0 Tdi Quattro Coupe, Grey
    2010 A6 Allroad 3.0 TDi, Blue
  4. Re: Removing the key doesn't switch off electrics (intermittent)
    Oct 2014
    Leeds, West Yorkshire
  5. Re: Removing the key doesn't switch off electrics (intermittent)
    Apr 2017
    Huddersfield
    I was reading earlier that it can be the 'weight' of the rest of the keys which weight down the audi key and can become intermittent connection. People have suggested to use just the single Audi key by itself which helped.
  6. Re: Removing the key doesn't switch off electrics (intermittent)
    2018 Post(s)
    The switch often fails on a 4F but is easy to change and not coded to the car or specific key, there are a number of versions depending on vehicle spec, 4F0 910 132 B, C, F, G, K, L, and Q, all at £253.36
  1. Audi A6 2.7 TDI Intermittent Electrics
    By Rolands in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-06-2012, 09:42 PM
  2. Remote central locking 1-Key works, the other doesn't??
    By platriani in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 15-02-2010, 12:28 PM
  3. Question Key Fob doesn't unlock boot and doors together
    By The Glove in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-09-2009, 05:18 PM
  4. Spare key doesn't open door!
    By Sqwim in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-01-2009, 11:59 PM
  5. My Aussie Bora doesn't like my key!
    By DantheVWMan in forum Bora - 1998 - 2005
    Last Post: 26-11-2007, 03:03 AM
