Thread: Avant roof rails and what bars?
Results 1 to 10 of 10
  1. Avant roof rails and what bars?
    Jun 2015
    Midlands
    The roof rails on the avant have 2 small holes on the inside which I presume is where the fitting kit part locates.
    ive just purchased some Thule equipment but it doesn't locate in the holes. You can slide it anywhere on the rail.
    my question is do Thule make a kit that locates in the holes or is it only the official Audi kit that does this?
    does anyone even have bars/fitting kit for sale???
  2. Re: Avant roof rails and what bars?
    Jun 2015
    Midlands
    No one got any roof bars fitted to their avant?
    ive bought the Thule 4001 fitting kit. Anyone running a different one with locating pins to fit the inside of the rail?
  3. Re: Avant roof rails and what bars?
    Feb 2015
    Wirral
    Are the Avant rails the same as those on the Allroad - raised, with a gap between the rail and the roof?
    If so, I fitted some Thule wing bar edge rails to my Allroad, they don't need the locating points, are very low profile andso I just leave them on the car when not in use. Theyr're not cheap, but I'm very pleased.
  4. Re: Avant roof rails and what bars?
    Apr 2009
    Surrey
    183 Post(s)
    Quote Originally Posted by Tinytimbo View Post
    Those holes are indeed for locating pins top hold the rails. I think the alternative Thule option that uses the 753 foot pack has the lugs but not sure about the lower profile option. The exploded diagram on the Thule website does not make it clear, it may just clamp on
  5. Re: Avant roof rails and what bars?
    Apr 2009
    Surrey
    183 Post(s)
    Quote Originally Posted by heavy_landing View Post
    No the Avant is different tot he Allroad and has flush rails with no gap rather than raised rails
  6. Re: Avant roof rails and what bars?
    Sep 2008
    Chichester
    I have the Green Valley Trek bars on my car. They came with 4 moulded blocks that locate into the holes on the roof rails and the bars then clamp onto these 4 blocks.
    Eeyore
    A6 Avant 2.0 TDIe 2009 (Facelift)
    Not worth starting anything now...."
  7. Re: Avant roof rails and what bars?
    Jul 2011
    Near Uxbridge
    On my Avant I use the holes simply as a guide as to where to fit the bars...mine don't have locating pins that fit into the holes. They are made by Atera. Don't worry if your bars don't have the pins...they won't come off.
    Sent from my HTC One using Tapatalk
    Consultation en ligne viagrasansordonnancefr.com immunite des francais
  8. Re: Avant roof rails and what bars?
    Dec 2008
    Stoke-on-Trent
    Ive been looking at a foot pack to use with my old Thule bars etc.
    My mate has a new Q5 that all seem to come with aero bars as standard, but never seem to get used. theres loads on ebay unopened from about £50.
    I have taken the footpack off and they will fit my A6 bars on my Lemans and locate perfectly in the holes.
    Obviously the bars are too long, but only by about 50mm
    The bars simply bolt onto the footpack with 2 allen bolts and the holes are slotted to give some adjustment.
    I recogn by drilling another hole either side and elongating with my dremel, I will have a good set of bars very cheap.
    Will keep you informed as I only picked them up last night
    Simon
  9. Re: Avant roof rails and what bars?
    Dec 2008
    Stoke-on-Trent
    Well the Q5 roof bars are on
    couple off things I found
    I mounted one foot and tightened it up. I then measure from mt6he front of the foot back to the inner face of the roof bars , 25mm approx.
    on the other side I did the same measurement, it was 20mm behind the face, plus the 25mm it should be in front, ie 45mm too long.
    I then chopped 45mm of one side and redrilled the holes and slots as the other side. This worked out nicely.
    The back ones are easy as they fit straight in. On the Q5 front drivers side the foot has 3 locating pins. nether mind, get the dremel out and cut the inner pin off.
    When I came to fit the front bars this side wouldn't fit the pins, Audi have decided to fit different spacing on this one foot, the 2 outer pins are 5mm further apart, out comes the dremel again and Im left with just 1 pin.
    As other have said some other makes of bars don't even have locating pins so this doesn't bother me, they are totally rock solid and look great.
    A great set of bars cheaper then replacing the foot pack on my Thules
    Simon
  10. Re: Avant roof rails and what bars?
    Nov 2018
    Bit of a blast from the past, but don't suppose you have any more pictures of your mods Simon? Just bought a set of Q5 bars for mine to mod.
  1. Genuine roof bars v Thule/whispbar for black roof rails
    By Adders21 in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 17-08-2015, 04:02 PM
  2. Genuine VW Roof Bars - Estate with factory fitted rails
    By MegPass in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 05-06-2014, 11:20 PM
  3. Roof bar for B5 A4 Avant (with roof rails) range £25.00 - £120.00+ why??
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-02-2013, 08:06 AM
  4. Roof Rails and Roof Bars
    By phantomdox in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-02-2011, 08:11 PM
  5. golf estate roof bars to fit rails
    By rotary in forum Golf MK4 - 1999 - 2004
    Last Post: 04-08-2008, 06:34 PM
