Thread: Mirror iPhone to display
Results 1 to 10 of 10
  1. Mirror iPhone to display
    Sep 2010
    Leigh on Sea
    I've tried searching but haven't found the info I need, sorry if it's a duplicate.
    I have a 2015 A6 with tech pack, I want to mirror my iPhone and audio to the screen (and sound system) what's the best way to do it.
  2. Re: Mirror iPhone to display
    Feb 2013
    Gloucester
    57 Post(s)
    Someone did it recently. There is a thread somewhere.
    Audi A7, S-line, 313 PS BiTDI Tiptronic, Daytona Grey, heated front and rear seats, Audi connect, quad zone climate control, ski chute and bag, Rear tints, 75 Litre fuel tank, All LED headlights, Night vision assistant, Rear view camera with corner view, Navigation plus, MMI touch, Heads up display, Adaptive Cruise control, Blind spot monitoring and active lane assist. Audi A5 (wifes) My Kit car blog - http://mitchsgbszero.blogspot.co.uk
  3. Re: Mirror iPhone to display
    Sep 2010
    Leigh on Sea
    My searches failed. Any idea what terms I should search for?
  4. Re: Mirror iPhone to display
    Aug 2013
    18 Post(s)
    Found it with "iphone app"
    Replicated my iPhone on MMI screen.
  5. Re: Mirror iPhone to display
    Sep 2010
    Leigh on Sea
    Thanks. I don't have the original AMI, I have the USB ports.
  6. Re: Mirror iPhone to display
    Aug 2013
    18 Post(s)
    So the app doesn’t work with the USB port?
  7. Re: Mirror iPhone to display
    Sep 2010
    Leigh on Sea
    Not from my jail broken 3GS, I don't want to JB my 6+.
    Ideally I'd prefer to get an AV input in to the system, then put an Apple TV in the car. Connected to the car's wifi, then connect the phone to the car's wifi and air play straight to it.
    I'll then have the Apple TV features in the car too.
  8. Re: Mirror iPhone to display
    May 2015
    London
    Hi
    This sounds really useful! I've got an old iPhone that I've jailbroken and downloaded display out. However, getting to the car I can't figure out which setting to use to mirror the display. What did you do in the car to get the display?
    Thanks in advance!
    Prav.
  9. Re: Mirror iPhone to display
    Mar 2014
    Edinburgh
    235 Post(s)
    Looked at something similar a while ago and I think it's not an easy task to achieve with the newer mmi plus.
    Firstly you will need to VIM done with vag can pro or a dongle from kufutec.
    you will then need an av source in for the mmi setup. Kufutec does packages for dvd in and other devices but not sure if this works with the newer mmi plus that's based on the A3 8V. I think because the mmi plus has USB ports instead of the ami ports( that has more pins)it's not capable of sending video to the screen and USB ports are pretty limited. If you use the Apple TV the mmi controls won't be able control the iPhone. Control will need to come from your phone or Apple TV.
    Might be worth posting something in the A3 forum and see if anyone has managed it.
  10. Re: Mirror iPhone to display
    May 2015
    London
    Quote Originally Posted by A6S View Post
    Thanks so much for this. Visited an audi retrofit place (Hazzydayz, St Albans) - they do lots of things but say mirroring won't be easy either. Got a few VCDS things coded at the same time so I'm a happy man!
  1. Question Audi iPhone 5/5s cradle. Compatible with iPhone 5c?
    By hilly703 in forum In Car Entertainment
    Last Post: 21-08-2014, 07:33 PM
  2. Question mirror iphone 5 to rns e
    By dart1114 in forum In Car Entertainment
    Last Post: 27-01-2014, 11:53 PM
  3. MMI connector Iphone 4 to Iphone 5
    By fz0rb4 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-11-2013, 09:29 AM
  4. Replies: 3
    Last Post: 08-09-2008, 05:22 PM
  5. A6 info display and auto dim mirror issues
    By lauriem in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-09-2006, 02:28 PM
