Thread: Clutch and flywheel
Results 1 to 9 of 9
  1. Clutch and flywheel
    Aug 2012
    London
    I need to change the clutch and flywheel, the biting point is really low and the flywheel is rattling like mad.
    GSF said that there are two types fitted, either sachs or LUK. They also advised that the sachs kit that comprises of the flywheel and clutch would fit, regardless of whether there is sachs or LUK currently fitted.
    Is this true?
    Could I fit a sachs flywheel and clutch regardless of what is there now?
    Btw it's a 1.9 tdi 2008
    Thanks!
  2. Re: Clutch and flywheel
    Aug 2011
    Meath
    LUK will also fit, either one should be good quality
    1 2 0
  3. Re: Clutch and flywheel
    Aug 2012
    London
    Thanks for the reply Doctle,
    Great, it was this kit i am looking at:
    FLYWHEEL AND CLUTCH KIT 022VG0070
    As long as this one will fit all will be good
    Oh, are there any fitting guides out there that would help me ?
  4. Re: Clutch and flywheel
    Aug 2011
    Meath
    Do you have a ramp? The gearboxes on these are heavy and there's a good bit of juggling to get it out and in around the subframe, if youre doing it on the ground. Don't allow the engine to hang unsupported off the mount. An assistant would help as would 2 or 3 trolley jacks. You don't need to drain the gearbox oil but it's good practice to renew gear oil with every clutch change. You'll need a torque wrench and an angle tightening gauge but it's a fairly easy clutch to do.
  5. Re: Clutch and flywheel
    Aug 2012
    London
    Thanks Doctle
    I have a pair of ramps and a couple of trolley jacks, a few axle stands and the torque wrench. I will need to pick up an angle tightening gauge.
    I'll get some new oil for the gearbox flush, good shout.
    Any 'how to' guides so I can avoid faffing and trying to figure out what to do next or where the bolts are hidden? Also, how long should I expect to take to do it?
    Thanks!
  6. Re: Clutch and flywheel
    Aug 2011
    Meath
    Takes about 5 hours in a workshop so allow 7-8 on the ground. The engine needs to be moved and held towards the front of the car so a hoist would be useful failing that a heavy block of wood between the bulkhead and the engine. The flywheel bolts are triple square heads I think so you'll need a set of those bits and pretty good quality too. You don't want to ruin the head on those bolts. Once you get the battery and airbox out you'll see what needs doing I don't have a guide but it's fairly straightforward.
  7. Re: Clutch and flywheel
    Aug 2012
    London
    i have bought a sachs kit from GSF and will give it a go soon.
    could someone confirm if the flywheel locking tool is necessary or if something can be made to block the flywheel without having to buy the tool?
  8. Re: Clutch and flywheel
    Aug 2012
    London
    just seen another:
    and have read that a prybar located carefully will suffice, any views?
  9. Re: Clutch and flywheel
    Aug 2011
    Meath
    2nd one is easily made and could save your knuckles
  1. Replies: 5
    Last Post: 08-04-2013, 09:23 PM
  2. Please Help intermittent clutch judder with new clutch & flywheel
    By FLENG2008 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-01-2013, 03:48 PM
  3. Question Replace clutch or CLutch and Flywheel? 2000 TDI
    By Mr Tibbs in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-10-2012, 06:14 PM
  4. Please Help Replaced flywheel and clutch kit......but still makes that clunk noise from the clutch :(
    By Zeb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-06-2011, 05:04 PM
  5. Clutch/flywheel
    By db1145 in forum Golf MK5 - 2004 - 2009
    Last Post: 18-02-2008, 12:25 PM
