 Re: A3 1.4 TFSI 150 - turbo lag? –
                            17-06-2015,10:49 AM
                            17-06-2015,10:49 AM
                        That doesn't sound right - I'd expect a lag when you press the pedal (if you're off boost) with a surge, then a drop off as the power goes off (unless you change gear).
If I floor it in first, I will get just your symptoms if I don't change up - if, however, your experience a surge and drop off even when smoothly pulling away, I'd get the dealership to check it out, just make sure you know how to, exactly, replicate the problem otherwise there will be a "no fault found" issue
                    Audi A3 Sportback 2.0 TDi SE: Misano  red, Kinetic 17s, Comfort package,  Storage package, non smoking package, Nav, Upgrade to Audi sound system, Debadged
