Thread: V5 Golf temp gauge and juddering problems - help please!!
  1. V5 Golf temp gauge and juddering problems - help please!!
    Hi all,
    I am after some advice so if anyone can help I am very grateful.
    I have recently brought my V5 and love it! Its 2001 and only done 30k miles with fvwsh.
    However, the temperature gauge has been going to 90 degrees, as usual, then bombing to zero. Then going to 90 again then down to zero on a regular basis - does anyone know the cause?
    Also, when i have been in traffic for 10 mins or so i get this vibration and juddering from the engine - it is hard to explain but its quite loud and only lasts about 10 seconds max. Does anyone know what that could be or have had similar? It has never happened whilst driving and only when stationary.
    Are the two linked?
    Any advice will be very gratefully received.
    Regards
    Kevin
  2. Re: V5 Golf temp gauge and juddering problems - help please!!
    Sep 2007
    The temp gauge problem will be the temperature sensor playing up. This caused the same problem with my 2000 1.8 cabrio, as well as erratic idling and overfuelling as this sensor does more than feed the temp gauge. It is easy to replace and costs about a tenner (from eurocarparts). It will have a cable with 4 wires going into the top and is held in by a plastic circlip (be quick in changing it cos when you remove it the coolant will come out !
    Paul
  3. Re: V5 Golf temp gauge and juddering problems - help please!!
    Thank you very much for your help Paul.
    I will buy the part and get it changed and hopefully this will sort it.
    One further question - what exactly is the noise/idling/vibrating caused by / coming from? Sorry for sounding stupid but is it serious and is it doing any damage? I was just a bit alarmed when it first came on!
    Kind regards
    Kevin
  1. Oil Temp Gauge
    By rob1380 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-02-2008, 09:01 PM
  2. Juddering problems with mk3 golf gti 16v (95)
    By ESibley in forum Golf MK3 - 1993 - 1999
    Last Post: 03-03-2007, 05:56 PM
  3. temp gauge
    By garying3980 in forum Passat - Archive Topics
    Last Post: 11-02-2007, 03:06 PM
  4. a4 2.8 oil temp gauge
    By markcass in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-01-2007, 01:42 PM
  5. TEMP GAUGE
    By GARY in forum Passat - Archive Topics
    Last Post: 30-11-2006, 05:14 PM
