Thread: Alhambra 07 tdi stylance air con
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: Alhambra 07 tdi stylance air con
    Jun 2015
    macduff uk
    Ok Guys...
    Found compressor to be ok.... Its controlled by relay 454 under the fuse panel driverside under dash....
    Shorted across t6 ( relay supply from fuse 29) to t8 which would be supply to compressor clutch.... Clutch engaged and ran
    So why is relay not switching to supply clutch ?????
    Relay earth t2 has good continuity to earth
    T6 to T2 ( through coil) is 12k ohm
    T1 TO Earth through air sensor is 5k ohm
    have replaced hp switch and ambient air sensor and had it recharged with no leaks showing
    am i missing anything here???
  2. Re: Alhambra 07 tdi stylance air con
    Jul 2015
    Sheffield UK
    Hi I have the exact same problem on an 05 sx. Just wondering if you had any success getting the a/c going? This is driving me mental! It seems everyone has problems with the a/c but theres hardly any info online. And none with a successful conclusion. Relay 454 is an expensive part! how do you test it before buying one? Also if you remove the side panel from the dash inside the drivers door you can see relay 454 its just possible to get a hand in and remove it without taking the fuse box out.
  1. Replies: 3
    Last Post: 21-07-2013, 12:59 PM
  2. Question Alhambra 1999 1.9 TDI air con pipe broken
    By Shamous in forum Alhambra
    Last Post: 20-02-2012, 11:25 AM
  3. Question Heated Screen Alhambra 54 plate 130 Stylance
    By westj66 in forum Alhambra
    Last Post: 14-12-2010, 12:27 AM
  4. WTD 17" Alhambra Stylance wheels
    By djbarren in forum Wheels and Tyres
    Last Post: 03-08-2009, 08:49 PM
  5. Stylance 2.0 TDI 2007 electrical
    By sackatatties in forum Alhambra
    Last Post: 23-07-2009, 05:58 PM
