Thread: Vw Golf blowing fuse 13
  1. Vw Golf blowing fuse 13
    Jun 2015
    GB
    Vw golf (diesel) 53 plate blows fuse 13 every time you press the brake pedal ... any ideas?
    Sent from my GT-I9305 using Tapatalk
  2. Re: Vw Golf blowing fuse 13
    Dec 2007
    8 Post(s)
    I would probably remove both bulbs first to eliminate them as the problem,after that I would be suspect a short circuit in cables.
    1 1 0
  3. Re: Vw Golf blowing fuse 13
    Aug 2011
    Meath
    F13 is for the brake lights, check the switch and check for shorts in the loom
  4. Re: Vw Golf blowing fuse 13
    Jun 2015
    GB
    Thanks Doctil, they have swapped out the switch still the same :-) ... when the fuse blows the glow-plug warning light comes on ... is that relevant? ...
    Sent from my SM-G920F using Tapatalk
  5. Re: Vw Golf blowing fuse 13
    Aug 2011
    Meath
    I would try Michael's tip with the bulbs, that way you should be able to narrow it down to one side or t' other
  6. Re: Vw Golf blowing fuse 13
    Jun 2015
    GB
    Will give it a try and report back : -)
  1. Fuse keeps blowing
    By Grizgut in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-05-2011, 11:03 AM
  2. blowing fuse
    By chris356 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-12-2010, 11:24 PM
  3. Question Fuse Blowing
    By moaning in forum 80 - 90
    Last Post: 03-08-2010, 11:40 PM
  4. Fuse keeps blowing......
    By Ruby in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-01-2010, 07:58 PM
  5. Please Help '04 1.9 golf Won't start after blowing fuse
    By jgtuk in forum Golf MK5 - 2004 - 2009
    Last Post: 06-07-2009, 09:43 AM
