Thread: Help with multitronic gearbox
  1. Help with multitronic gearbox
    Jun 2015
    Bucks
    Advice needed with my wife's A4 cabriolet 2006. The in gear dashboard display has the red background illuminated. The car drives fine with the gear selector in drive but will not change gear if you try and use the paddles or the selector. The car will just stay in drive. Any ideas as to where the fault may lie. Thanks
  2. Re: Help with multitronic gearbox
    Southern County Softy
    20 Post(s)
    Try a search using "multicronic".
    A fault scan is the first thing to have which should point the way with fault finding.
    I believe there is a Co. in Milton Keynes that specialise in the repair of these boxes.
    A4 2.5 tdi QS (mapped)
  3. Re: Help with multitronic gearbox
    Jun 2015
    Bucks
    Quote Originally Posted by kite View Post
    Thanks, all research points to the ecu but I did hear a snippet that it maybe a cable problem attached to the selector on the cabriiolets
  4. Re: Help with multitronic gearbox
    20 Post(s)
    Fault scan first to see the logged codes
  1. Multitronic Gearbox oil
    By dufferum in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-02-2015, 09:56 AM
  2. Q5 Multitronic Gearbox
    By bchase in forum Q5
    Last Post: 19-02-2014, 12:43 AM
  3. 6 speed multitronic gearbox
    By phil frohwein in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-08-2011, 07:43 AM
  4. Multitronic gearbox
    By slice636 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-10-2009, 01:47 PM
  5. A6 1.8T Multitronic Gearbox Failure
    By Herbiv4 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-12-2007, 08:08 PM
