Thread: Audi A8 D3 2004 - CD Changer 8X0 / 4E0
Results 1 to 9 of 9
  1. Audi A8 D3 2004 - CD Changer 8X0 / 4E0
    Jun 2015
    London
    Hello Guys ,
    I have recently bought audi a8 with a faulty CD changer. Its the 4E0 xxx 111 - non mp3 version. I tried to repair it but its a bit hopeless. I have found online cd changer at a decent price but its part number is 8X0 035 110 <- this is i believe the newer model, but will it fit and work with my D3 ?? I have heard that 3G devices are backward compatible.
    Or if you know what is the correct part number i require (MP3) i would appreciate if you could tell me .
  2. Re: Audi A8 D3 2004 - CD Changer 8X0 / 4E0
    46 Post(s)
    You'd be best just buying one from the era your car is from, ie MMI2G High.
    4E0 910 110 E is definitely a 2G changer and is MP3 compatible.
    Whichever changer you go for however you will need a thing called component protection removed by Audi or an independent who has the facility to do so.
  3. Re: Audi A8 D3 2004 - CD Changer 8X0 / 4E0
    Jun 2015
    London
    The ones i have found with matching serial no cost around 110 - 160 pounds . The 8X0 .... i have found for 1/2 price. Hence i was wondering if it will fit. There is no hope i guess ?
  4. Re: Audi A8 D3 2004 - CD Changer 8X0 / 4E0
    46 Post(s)
    I'm afraid with a car with MMI you need to expect to pay big for parts. You may or may not see issues with the 3G one hence why stay with what was made specifically for 2G.
  5. Re: Audi A8 D3 2004 - CD Changer 8X0 / 4E0
    Apr 2015
    United Kingdom
    Just check if returns apply and go for it .
    0 0 1
  6. Re: Audi A8 D3 2004 - CD Changer 8X0 / 4E0
    46 Post(s)
    Quote Originally Posted by c3nturi0n View Post
    why when you still need component protection removed @ 1hr labour at audi?
    you'd be better off just buying the correct changer for the system and not hope and guess whether it'll work or not.
  7. Re: Audi A8 D3 2004 - CD Changer 8X0 / 4E0
    Jan 2010
    United Kingdom
    Or take the opportunity to bin the changer and put AMI in its place instead so you can just use an Ipod or hard drive...
  8. Re: Audi A8 D3 2004 - CD Changer 8X0 / 4E0
    Apr 2015
    United Kingdom
    Or as option #3 search on Kufatec site and add a device similar (to AMI) that would also give you access to B'tooth streaming (a2dp) for a fraction of the price. And i think (please check) that you can retain original cd changer or at least be in position to use when/if required.
    Hope that helps
  9. Re: Audi A8 D3 2004 - CD Changer 8X0 / 4E0
    Jun 2006
    UK, Mids
    It looks the same and has the MOST connector, but some sellers one eBay say 2008-on only WILL NOT WORK WITH EARLIER CARS -
    so probably true. I have the 110 MP3 player, it is a step up from the CD-ROM player but it would have to be cheap to warrant buying over an AMI.
    Mine was £40 a few years ago as someone misspelled it in the listing and did not have the part number in the listing.
    If it was >£100 for the MP3 optical drive, I would get an AMI (or a clone http://allegro.pl/audi-ami-4-mmi-2g-...435020541.html ).
    I don't even have a CD drive in my laptop or computer at work anymore and have to borrow the wife's laptop, if that broke it would be a PITA.
    Audi A8 - 2015 - 3.0TDI
  1. Question Which six disc changer for 2004 A4 B6 saloon S line
    By marcus gp1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-02-2014, 06:22 PM
  2. How To Audi concert Aux in through CD changer, but can’t select Changer on head why?
    By eddie_baby in forum In Car Entertainment
    Last Post: 13-06-2012, 05:47 PM
  3. 6cd changer into 1 cd changer mmi basic straight swop?
    By Quattros in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-09-2011, 12:08 PM
  4. Replies: 0
    Last Post: 11-06-2011, 12:23 PM
  5. 2004 A3 swap 6CD changer for new cd player
    By jayjones298 in forum In Car Entertainment
    Last Post: 15-01-2011, 12:11 PM
