Thread: PLEASE HELP ... my Cordoba keeps cutting out
  1. Exclamation PLEASE HELP ... my Cordoba keeps cutting out
    Oct 2007
    My partner has a 1995 Cordoba CLX and it's a great car ... but recently it has developed an annoying problem. When driving along, for no reason at all it can cut out! She is understandably a bit wary of driving it now.
    So far, this has only happened at low speed (<30 mph) and at low rpm when changing gear (i.e when the rpm drops during a gear change)
    Initially, we replaced the distributor and things improved ... so we thought it was the ignition system. We have subsequently replaced all plugs and leads and yesterday I changed the coil ... and it still keeps on cutting out!
    A colleague of mine at work has suggested that it might be the crankshaft sensor ... but I also remember seeing a post on here a short while ago that suggestes it might be something else ...
    I am at a complete loss ... can anyone help ...???
    Dave
  2. Re: PLEASE HELP ... my Cordoba keeps cutting out
    Oct 2007
    Belgrade,Serbia
    Take look at the throtle body
  3. Re: PLEASE HELP ... my Cordoba keeps cutting out
    2019 Post(s)
    What engine is it? Was the distributor fitted a used one?
  4. Re: PLEASE HELP ... my Cordoba keeps cutting out
    Oct 2007
    The distributor was a new one ... to be honest, I have no idea what engine it actually is ... any way I can tell ...?
  5. Re: PLEASE HELP ... my Cordoba keeps cutting out
    2019 Post(s)
    If you have the service book it will be a three letter code next to "Motor code" and also on a sticker on the boot floor. The cam cover in the engine bay will also have a bar code sticker that has the engine code on. Failing that, PM me the registration number and I will find out for you.
  6. Re: PLEASE HELP ... my Cordoba keeps cutting out
    Oct 2007
    Had the same problem with my cordoba. Turned out to be the fuel pump inside the petrol tank stopping and starting. The Fuel pump fuse (Number 13 i think under the drivers glovebox - yellow in colour ) kept blowing or would develop an intermittent connection causing the car to just die at very inconvenient times. VW wanted $875.00 for a complete unit so i told them to stick it where it dont pump.
    Found a brand new unit on EBAY California for $110.00. Only took 4 days to arrive! to brisbane .
    Link below:
    http://cgi.ebay.com/ebaymotors/NEW-F...mZ110185461982
  1. Cordoba TDI BHP???
    By cordtdi in forum Ibiza - Cordoba
    Last Post: 23-02-2008, 10:18 PM
  2. my cordoba won't go into 1st gear
    By anto2007 in forum Ibiza - Cordoba
    Last Post: 22-10-2007, 10:34 PM
  3. 96 Cordoba Stereo Wiring.
    By blacklight in forum Ibiza - Cordoba
    Last Post: 20-10-2007, 12:00 AM
  4. how to fit fog light to my cordoba
    Last Post: 17-10-2007, 08:14 AM
  5. 2002 Cordoba Radio removal questions
    By be11y in forum Chat - Anything with wheels
    Last Post: 20-09-2007, 07:30 PM
