Thread: Airbag short to ground
Results 1 to 10 of 11
  1. Airbag short to ground
    Oct 2014
    TAUNTON . SOMERSET
    Fault code says is short to ground drivers side airbag.done rewire under seat. But still got fault and airbag light. Car is 04 a4 b6 1.9tdi quattro. Help guys please. Its only fault driving me crazy.
  2. Re: Airbag short to ground
    May 2007
    17 Post(s)
    Did you clear the code after doing the wiring repair?
    If your Audi is like VWs there is another connector under a cover on the floor at the front of the seat. Disconnect the yellow connector there and then recheck the fault code. If the short to ground is now shown as intermittent and you have a new static code saying something like "upper limit exceeded" then it's either the airbag itself that's shorted or a short on the seat base wiring somewhere. The "upper limit exceeded" code tells you that the wiring between the connector at the seat and the airbag ECM is OK, so the fault must be on the seat.
    Jim.
  3. Re: Airbag short to ground
    Oct 2014
    TAUNTON . SOMERSET
    Thanks m8. Yeah its got another connector in that place. I delete fault after repair. And after couple minutes drive its come back. I try that u suggest. That if i cut of that connector too?
  4. Re: Airbag short to ground
    May 2007
    17 Post(s)
    Quote Originally Posted by Martynas26 View Post
    I don't think a connector is the problem. A loose connection on a connector would give you the "upper limit exceeded" trouble code, not a short to ground.
  5. Re: Airbag short to ground
    Oct 2014
    TAUNTON . SOMERSET
    On connector is two wire one black & one blue. Close to is running thick brown cable. Is the one which shortening?
  6. Re: Airbag short to ground
    Oct 2014
    TAUNTON . SOMERSET
    I will do thing thats in your first post. To get any progress and faults.
  7. Re: Airbag short to ground
    May 2007
    17 Post(s)
    On airbag system, a short to ground code usually means the wiring has rubbed through on to the body somewhere. If you disconnect the connector at the seat like I suggested, then recheck the code that will give you a clue where the damage to the wiring is. If the short to ground code changes status to "intermittent/sporadic" once the seat connector is unplugged that tells you the damage must be on the seat base. If the short to ground code remains "static/present" then the damage is on the wiring between the connector under the floor and the airbag control unit.
    If the two wires on the airbag connector to had shorted together your trouble code would more likely be "lower limit exceeded".
    Lower limit exceeded means the circuit resistance is too low (shorted together) and upper limit exceeded means the resistance is too high (open circuit).
  8. Re: Airbag short to ground
    Oct 2014
    TAUNTON . SOMERSET
    Thanks alot. You give me more understanding on that these words means. I do the tests tomorrow and write the outcome. Thanks again.
  9. Re: Airbag short to ground
    Oct 2014
    TAUNTON . SOMERSET
    I disconnected connector under carper and yeah the fault code went to uper limit exeded.do test drive to see or short to groun will back but its not. So problem will be in the seat. But dont want to rip all seat apart to check wiring.
    But still it is easy to remove airbag?
  10. Re: Airbag short to ground
    May 2007
    17 Post(s)
    I've never had to replace a side airbag on a VW/Audi. You'd need to unhook the seat back fabric at the bottom and roll it up towards the top to expose the airbag. You might need to split the seat back from the base to unhook the fabric. The airbag itself will probably be secured to the seat frame by a couple of 10mm nuts.
    The fault code suggests it's the wiring that's rubbed through or has been trapped somewhere on the seat base though as opposed to the airbag itself being faulty.
  1. parking sensors Open or Short to Ground after resetting
    By djpibody in forum VCDS - Help Requests
    Last Post: 28-07-2013, 09:16 PM
  2. Update On Door Handle Touch Sensor (G418) 007 - Short to Ground
    By 66Cobra in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 08-04-2012, 10:05 PM
  3. Door Handle Touch Sensor (G418) 007 - Short to Ground
    Last Post: 28-03-2012, 07:38 PM
  4. Ground Earth Short
    By v12bug in forum VCDS - Help Requests
    Last Post: 08-08-2010, 04:39 PM
  5. Please Help 00518 - Throttle Position Sensor (G69) 31-10 - Open or Short to Ground - Inter
    By Housemaster300 in forum Golf MK3 - 1993 - 1999
    Last Post: 26-07-2010, 12:05 PM
