Thread: Electronic Handbrake Question
Results 1 to 10 of 16
  1. Electronic Handbrake Question
    Jul 2013
    Cardiff
    When locking the car, does your handbrake auto engage if you've forgotten to pull the button up?
    In a rush with the kids last week and got out without engaging the handbrake - was able to turn engine off, get out, lock car and then noticed car was slowly rolling forward before hitting the garage door.
    Is this normal?
    Seems bonkers that modern cars squark at you like it's the end of the world if you leave your light on, but not if you've left the handbrake off! Isn't that a kind of advantage of electronic handbrakes ??
  2. Re: Electronic Handbrake Question
    Mar 2015
    Cardiff
    6 Post(s)
    As soon as I stop and put mine into park (auto) and take my seatbelt off it automatically turns on. However I always pull it up to make sure.
  3. Re: Electronic Handbrake Question
    Jul 2013
    Cardiff
    Thanks Chris81 - should have mentioned mine is a manual.
  4. Re: Electronic Handbrake Question
    46 Post(s)
    i enabled this on an auto a6 i had on loan.
    not sure if it works with manual cars though and this works by shifting to park. im pretty sure i didn't see anything relating to epb on keylock.
    Quote Originally Posted by Chris View Post
    I'll get you some pics soon but I found another feature you automatic owners might enjoy.
    53 - Parking Brake
    16 - Security Access
    Code shown to me was 78713
    10 - Adaption
    "Shift P to EPB"
    Set to Activated
    This will auto-apply the handbrake when the shifter has moved to P.
  5. Re: Electronic Handbrake Question
    Aug 2014
    Shrewsbury, Shropshire, England
    Our handbrake auto applies when we turn off the ignition and ours is a manual 2012
    Andy
  6. Re: Electronic Handbrake Question
    Tripletrouble Guest
    Mine doesn't. 2013 manual.
  7. Re: Electronic Handbrake Question
    Apr 2009
    Surrey
    183 Post(s)
    Quote Originally Posted by Pikey Narna View Post
    Andy
    I will check later but pretty sure mine only does this if I have activated the auto hill hold function. Manual 2012
  8. Re: Electronic Handbrake Question
    May 2014
    Bath, UK
    As above, with a combination of the VCDS option and the auto-hill-hold button, you should be able to get it working.
  9. Re: Electronic Handbrake Question
    Nov 2012
    Somerset UK
    Hope you get it sorted.
    Have driven auto's for over 30yrs and hardly ever use the handbrake, just move it to park (which you have to do to remove the key) and it rolls a few inches before wheels lock.
    Downside is that have to ensure that I give the handbrake a good workout prior to MOT time
  10. Re: Electronic Handbrake Question
    Dec 2010
    CD UK
    6 Post(s)
    Quote Originally Posted by MarkTM View Post
    Very very occasionally I do this on my C6 and then cringe when the car stops rolling. OK, its on an almost flat driveway, but I can't help feeling its not very sympathetic to the drive train.
    Maybe I'm overcautious as I also release the EPB switch manually every (and I do mean every) time, rather than letting the transmission overcome the brakes. The last time I admitted to this I got a few "Why?"s and the odd "like", although I feel somewhat vindicated now after reading Honest John suggesting that a lot of (premature) rear brake wear is down to the EPB system's auto release.
    1 1 0
  1. electronic handbrake
    By perrymatt in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 06-05-2013, 08:57 PM
  2. electronic handbrake
    By offaly007 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-06-2011, 09:33 PM
  3. Electronic handbrake
    By phildefreitas in forum A8 - S8 - V8
    Last Post: 01-08-2009, 06:25 PM
  4. Electronic Handbrake
    By slimgeo in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-02-2009, 09:50 AM
