Thread: Coolant warning light 1.9tdi
Results 1 to 10 of 10
  1. Coolant warning light 1.9tdi
    Sep 2009
    essex UK
    I have a 2002 1.9tdi 130 AWX with 282000 on the clock and the coolant warning light started appearing on the dashboard intermittent and now permanent, also the temperature gauge doesn't move from zero.
    The car has a new genuine Audi thermostat which was working fine as was the temperature gauge before this issue.
    There is no overheating and no loss of coolant.
    I replaced the plastic expansion tank thinking it may be the sensor in there but on replacing it the coolant warning light is still there.
    Any help with this issue would be greatly appreciated.
  2. Re: Coolant warning light 1.9tdi
    Aug 2011
    Meath
    A scan might be helpful. Did the temperature gauge stop working when the light became constant. Could be CTS
    2 1 0
  3. Re: Coolant warning light 1.9tdi
    Sep 2009
    essex UK
    Thanks for your quick reply. The temperature gauge stopped working when coolant light was intermittent as well, then worked again every time coolant light was off.
    I'll do as you suggested and get it scanned.
  4. Re: Coolant warning light 1.9tdi
    Aug 2011
    Meath
    Id replace the CTS it only costs a score or so
  5. Re: Coolant warning light 1.9tdi
    Sep 2009
    essex UK
    I'll replace it as it's not expensive. I'm sure I replaced it three years ago but I do a lot of mileage and maybe wants doing again.
    Thanks again.
  6. Re: Coolant warning light 1.9tdi
    Sep 2009
    essex UK
    Hi all, an update on this issue, I've replaced the CTS and the dashboard still shows the coolant warning light and the temperature gauge still doesn't move from zero.
    I went to my local Audi specialist for a diagnostic and they think it's the dash panel.
    The dash panel returned the following data:
    Live data of the dash said minus 110 degrees
    The ECU was ok.
    Has anyone had a similar issue with the dash panel?
    I don't know whether to live with it due to the cars mileage or send it to be fixed if that is the issue!
  7. Re: Coolant warning light 1.9tdi
    Sep 2008
    chester
    17 Post(s)
    With 282k under her belt and its running ok i'd be tempted to leave it,having said that these things do bug us if you want your motor spot on,try a salvaged one maybe.
  8. Re: Coolant warning light 1.9tdi
    Oct 2014
    TAUNTON . SOMERSET
    Do u have just one cts or two? One on the back of the engine and second on bottom of the radiator.
    Sent from my C6903 using Tapatalk
  9. Re: Coolant warning light 1.9tdi
    Sep 2009
    essex UK
    I'm not sure if there's a cts at the bottom of the radiator on my model or not. I've replaced the engine one. Is there one on your car Martynas26?
  10. Re: Coolant warning light 1.9tdi
    Aug 2011
    Meath
    There's only 1 CTS and it's on the engine. Any replacement must be genuine as the spurious ones seem to be made to keep the light off rather than work properly
    By swampey in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-05-2012, 03:40 PM
  2. Important My Audi a4 1.9tdi problem ESP light and glow plug system warning light
    By Ock00 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-02-2011, 01:33 AM
  3. Coolant warning light
    By xb25436 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-11-2010, 10:44 PM
  4. Coolant warning light
    By Scrub in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-06-2010, 02:46 AM
  5. Coolant Warning Light
    By wanna in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-03-2008, 09:32 PM
