Thread: Mechanic wants to check wiring looms under the carpet
  1. Mechanic wants to check wiring looms under the carpet
    May 2015
    Canterbury
    Got the following faults which all happened at the same time
    ESP Light on
    Fan Runs constantly
    Heater/Air Con does not work/switch on
    and mechanic wants to do continuity checks on the wiring looms under the carpet, and I'm thinking the carpet will never fit the same again, any comments?
    ps: He did a Fault code check and it came up with P1857, which doesn't pin point anything.
    What would you consider?
  2. Re: Mechanic wants to check wiring looms under the carpet
    46 Post(s)
    What did he scan the car with?
  3. Re: Mechanic wants to check wiring looms under the carpet
    Nov 2012
    Somerset UK
    Useful stuff to post
    1) How long have you had the car?
    2) Which year/engine/transmission/mileage
    3) How long ago did the faults occur and did you have any work done to or changes to the car, anything as minor as changing the battery
    4) Was VCDS used to scan it if not what scan tool
    5) A google of the fault code brings up quite a bit, have you attempted this?
    For example:
    ESP Fault | Audi Forum
  4. Re: Mechanic wants to check wiring looms under the carpet
    May 2015
    Canterbury
    It's a 2005 a6 S line, manual, with 145k miles on it.
    I've had it from 2 years old and 60k miles
    Engine was replaced about 2 years ago due to oil pump failure and new turbo and clutch replaced at same time
    new EGR valve too!
    the fault has been there about 2 weeks now and he used a Snap On fault finder.
    Since the fault we replaced the MAF sensor, well I did, since a lot of people on google suggested it could be this. But nope, same fault.
    not even sure it's all linked, but seems odd it all happened same time
  5. Re: Mechanic wants to check wiring looms under the carpet
    46 Post(s)
    Scan it with VCDS before doing anything else as some other tools can misread fault codes.
  6. Re: Mechanic wants to check wiring looms under the carpet
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by JAYBONE View Post
    ESP Light on
    Fan Runs constantly
    If taken out right it will fit fine and you'll never know, only issue removing carpet I see is it has these shaping plastic pieces in it and if not handled correctly they tear out of sponge backing on carpet.
    That EOBD code means
    EOBD II Error Code: P1857
    Fault Location:
    Engine Control Module (ECM) - Load Signal Error Message
    Possible Cause:
    Malfunction Indicator Lamp (MIL)(K83) active.
    Fault Code(s) stored in Engine Control Module (ECM).
    Possible Solutions:
    Check Engine Control Module (ECM) for Fault Code(s).
    Personally I'd not be getting carpet removed to get looms checked under it. Why I say this is I've had my interior out quite a few times and can't see why the looms under carpet would be what he'd need to access.
    Looking at the EOBD code I'd be looking at ECU / Engine looms if looking for wiring fault.
    As stated get a VCDS scan, in Chris's signature is a map of forum members with VCDS perhaps you can find one close to use and get one done.
    1 1 0
  1. Question Wiring looms
    By 5m4 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-10-2012, 10:43 PM
  2. Please Help Concert wiring looms/leads???
    By Zeb in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-09-2009, 11:28 AM
  3. Spade connectors for buildin wiring looms
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-04-2009, 02:23 PM
  4. Towbar wiring looms
    By Firkle in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 07-05-2008, 02:39 PM
  5. are interior wiring looms the same ?
    By figdet in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-03-2008, 10:29 AM
