Thread: Multiple fault codes after car gradually loses power and drive
Results 1 to 10 of 16
  1. SOLVED: Multiple fault codes after car gradually loses power and drive
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Short description of events: Dropped someone off at work noticing that car seemed to be "holding back" on the way. Drove back through a village at 30 mph and engine warning light (the glow plug generic one) came on. Car starts to slow down despite foot remaining in same place on accelerator eventually not moving more than 5mph so I pulled over and switched off but beforehand noting that the idle revs were just over 1000 rpm (normally bang on 800 - unerringly consistent too for a car with 156K on the clock). Waited for a few minutes and tried to restart, warning light still flashing, car turns over but does not fire. This is repeated 4 more times with no joy on starting and exhaust gas warning light illuminates also during this but may be as a result of the failed starts. Turned off and waited another few minutes and decided to try once more before calling recovery service. Warnings lights are off this time and car starts! Got her back home and scanned with VCDS to find lots of codes in different modules - some I already knew about.
    Here are the scan results:
    Address 01: Engine Labels: 03G-906-018-BMN.clb
    Part No SW: 03G 906 018 AS HW: 03G 906 018 AS
    Component: R4 2.0l PPD1.2 G 9971
    Revision: --H42--- Serial number: VWZCZ000000000
    Coding: 0000078
    Shop #: WSC 00338 210 91434
    VCID: 76CD3B910156C891443-8023
    4 Faults Found:
    012600 - Intake Manifold Runner Control
    P3138 - 006 - Regulation Deviation - Intermittent
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 40
    Mileage: 248349 km
    Time Indication: 0
    Date: 2015.05.16
    Time: 10:19:58
    Freeze Frame:
    RPM: 1824 /min
    Torque: 136.0 Nm
    Speed: 25.0 km/h
    Mass Air / Rev.: 654.0 mg/str
    Mass Air / Rev.: 670.4 mg/str
    Lambda: -27.3 %
    Text: Kein Messwert verfuegbar
    005214 - Mass Air Flow during Regeneration too Low
    P145E - 006 - - Intermittent
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 248347 km
    Time Indication: 0
    Date: 2015.05.16
    Time: 10:05:51
    Freeze Frame:
    RPM: 1856 /min
    Torque: 40.0 Nm
    Speed: 40.0 km/h
    0.00 %
    11.31 %
    Mass Air / Rev.: 337.9 mg/str
    Mass Air / Rev.: 528.6 mg/str
    001602 - Sensor Reference Voltage A: Circuit
    P0642 - 007 - Low - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100010
    Fault Priority: 5
    Fault Frequency: 10
    Reset counter: 40
    Mileage: 248348 km
    Time Indication: 0
    Date: 2015.05.16
    Time: 10:08:28
    Freeze Frame:
    RPM: 0 /min
    Torque: 48.0 Nm
    Speed: 0.0 km/h
    Voltage: 1.95 V
    Hex Value: 0x0002
    Voltage: 11.75 V
    Voltage: 11.98 V
    000802 - Engine Speed Sensor (G28)
    P0322 - 006 - No Signal - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100001
    Fault Priority: 5
    Fault Frequency: 10
    Reset counter: 40
    Mileage: 248348 km
    Time Indication: 0
    Date: 2015.05.16
    Time: 10:08:28
    Freeze Frame:
    RPM: 0 /min
    Torque: 48.0 Nm
    Speed: 0.0 km/h
    Bin. Bits: 00000001
    Bin. Bits: 01000011
    (no units): 11.0
    Angle: 0.0 °
    Readiness: N/A
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
    Component: Bordnetz-SG H52 2002
    Revision: 00H52000 Serial number: 00000006648006
    Coding: E9800F0700041A00470A00000F00000000395D435C0001
    Shop #: WSC 05311 123 12345
    VCID: 6CF919F94F1A0241A27-8039
    Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer 220107 022 0601
    Coding: 00046997
    Shop #: WSC 05311
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 030410 054 0403
    Coding: 00471213
    Shop #: WSC 05311
    3 Faults Found:
    02071 - Local Databus
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 247200 km
    Time Indication: 0
    Date: 2015.05.04
    Time: 15:37:00
    Freeze Frame:
    OFF
    Voltage: 12.50 V
    OFF
    ON
    OFF
    OFF
    OFF
    01334 - Door Control Module; Rear Right (J389)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 30
    Mileage: 247252 km
    Time Indication: 0
    Date: 2015.05.05
    Time: 08:42:00
    Freeze Frame:
    OFF
    Voltage: 12.60 V
    OFF
    ON
    OFF
    OFF
    OFF
    01520 - Rain and Light Recognition Sensor (G397)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 36
    Mileage: 247200 km
    Time Indication: 0
    Date: 2015.05.04
    Time: 15:37:00
    Freeze Frame:
    OFF
    Voltage: 12.50 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
    Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
    Component: Gateway 007 0040
    Revision: 00007000 Serial number: 0700C07131022D
    Coding: 3FFD0C04E61003
    Shop #: WSC 05311 000 00000
    VCID: 216738CDF8581F29411-8074
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 247252 km
    Time Indication: 0
    Date: 2015.05.05
    Time: 08:42:36
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No: 1K0 035 186 T
    Component: Radio GR0 020 0023
    Revision: 0002006S Serial number: VWZ2Z2G2225358
    Coding: 0042402
    Shop #: WSC 05314 000 00000
    VCID: 3753F69546DC71999F5-8062
    1 Fault Found:
    00857 - CD Changer Unit (R41)
    014 - Defective - Intermittent
    Address 77: Telephone Labels: 3C0-035-730.lbl
    Part No SW: 7L6 035 730 HW: 7L6 035 730
    Component: Telefon 2209
    Revision: 00011000 Serial number: 0000000008709
    Coding: 0020035
    VCID: 6BFB1AE54A140579ABD-803E
    1 Fault Found:
    00992 - Consumption Cut-Off Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 61
    Mileage: 248348 km
    Time Indication: 0
    Date: 2015.05.16
    Time: 10:10:22
    All those dated 16.05.2015 are related to this mornings loss of drive.
    Any ideas as to where to start? Battery?? Faulty electrics somewhere?? Any measuring blocks in VCDS to look at battery capacity etc.?
    Car running fine at present, back to its 800 rev consistent idle and revs freely with no "pull back". New alternator only 15,000 miles ago but ORIGINAL battery.
    Thanks.
  2. Re: SOLVED: Multiple fault codes after car gradually loses power and drive
    Jan 2012
    10 Post(s)
    88 Post(s)
    Just to add...I have a vacuum operated swirl flap mechanism and therefore will renew the tubing, MT2 vacuum solenoid switch (looks like a smaller N75 solenoid valve) and runner actuator to cure the Inlet Manifold Runner control error. The EGR valve and throttle body was cleaned around 30,000 miles ago but not the inlet manifold. I'm going to do this again along with cleaning the manifold and entire intercooler / pipework as there is a build up of oil in the intercooler system from the crankcase vent (cam cover to pre turbo intake pipe) that has reached the exit side of the intercooler itself now and probably up the throttle intake pipe mixing in with the exhaust gas entering the EGR (before it goes into the throttle body then manifold). The electric motor operating the EGR valve will get a once over or replacement to ensure the valve is operating smoothly.
  3. Re: Multiple fault codes after car gradually loses power and drive
    Sep 2008
    SE London
    Yikes! Original battery They're good those OEM factory-fitted Molls, but not that good. Mine started delivering less power (and not holding charge) after five years on my '06MY. Went on to do another winter's service jump starting neighbour's Mondeo. Change out for a Bosch S5008, 77AHC. Many eBay suppliers that'll deliver to your door, it's a cut-throat business so expect to pay no more than £80 inc all inc delivery.
    Can't see from your Autoscan what your mileage is but current faults are mixed up with previous ones. So, after battery changeout, go into each module and clear all faults. And then see what comes back.
    Any help?
  4. Re: Multiple fault codes after car gradually loses power and drive
    Norfolk
    Manifold intake flaps have failed. get it checked quick. if one breaks and goes in the engine. eek!!
    1 1 0
  5. Re: SOLVED: Multiple fault codes after car gradually loses power and drive
    Jan 2012
    10 Post(s)
    88 Post(s)
    Update: Plastic intake pipe had split underneath just after the MAF sensor thus a certain volume of air was bypassing it. Fault code "005214 -*Mass Air Flow*during Regeneration too Low"*therefore solved and replacement pipe fitted.
  6. Re: SOLVED: Multiple fault codes after car gradually loses power and drive
    Jan 2012
    10 Post(s)
    88 Post(s)
    Quote Originally Posted by martin1810 View Post
    Thanks Martin, I had suspected some fouling of the inlet manifold flaps and at over 150K the plastic can't be in the best of condition. The fault seems to occur every day so the manifold is coming off pronto!
  7. Re: Multiple fault codes after car gradually loses power and drive
    Sep 2008
    SE London
    Quote Originally Posted by DMitch16 View Post
    Interesting for a pipe split. The fault's only shown in your Autoscan the once
  8. Re: Multiple fault codes after car gradually loses power and drive
    Jan 2012
    10 Post(s)
    88 Post(s)
    Quote Originally Posted by RichardSEL View Post
    The spring clip wasn't on properly either and the pipe had slipped of at the flange. I am thinking now that the code was for the pipe coming off not the split (which I may not have discovered for a while if the pipe had not come off). MAF code has not returned.
  9. Re: SOLVED: Multiple fault codes after car gradually loses power and drive
    Jan 2012
    10 Post(s)
    88 Post(s)
    Latest update: All codes cleared and engine ran for a few minutes. Engine then threw the two codes relating to 001602 - Sensor Reference Voltage A: Circuit P0642 - 007 - Low - Intermittent - MIL ON and 000802 - Engine Speed Sensor (G28)*P0322 - 006 - No Signal - Intermittent - again!
    These two seemed to be linked and are on the same loom as the V157 flap motor which has thrown up numerous codes in the past (but not this time).
    I'm stumped (electrics not my strong point). Any suggestions?
  10. Re: Multiple fault codes after car gradually loses power and drive
    vespa Guest
    New batteries are super discounted at ECP this week. Maybe worth a look.
  1. Question 2007 A4 2.0 TFSI with multiple fault codes
    By lasosage in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-09-2014, 02:13 PM
  2. Question Bad car Any suggestions? Fault codes
    By richieski in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-05-2013, 08:10 PM
  3. asz engine no power no fault codes
    By 1.8t bus in forum Golf MK4 - 1999 - 2004
    Last Post: 10-12-2011, 10:39 PM
  4. Question No fault codes - No power
    By derekh in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-06-2010, 08:16 PM
  5. Please Help TDI loss of power multiple Vag-Com codes
    By norfolkboy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-03-2010, 11:03 PM
