Thread: mk2 golf gti 1990 (Mk1 Cabriolet)
Results 1 to 8 of 8
  1. mk2 golf gti 1990 (Mk1 Cabriolet)
    brighton
    i hear and constant whining from under the car just by rear wheels drivers side
  2. Re: mk2 golf gti 1990
    Aug 2007
    Northern Ireland
    When ignition is on? Could be the fuel pump, but as I said in a previous post i'm not very well up on the gti
    If it is, there must be a pressure loss somewhere, the pump should run til the fuel pressure is at a preset value then cut out (Unless the car is running)
    If it's only when the car is running then this is normal.
    Pete
    52 plate Golf GT TDi
  3. Re: mk2 golf gti 1990
    Canada
    It is the fuel pump and it quite normal for a MK1 GTI cab (there was never a MK2) The injection system on a MK1 is the Bosch Jettronic and it pumps 90% of the fuel around the system unused, the pump works very hard The fuel injection system is an electro-mechanical system unlike the later injection systems on the MK2 Gti's
    there is some good info on this site about mk1 cabs
    http://www.cabby-info.com/
    My Old mk1 Cab 1990
  4. Re: mk2 golf gti 1990
    brighton
    cheers for that is it normal for the fuel pump to whine that loud though? (Mk1 got it...lol)
  5. Re: mk2 golf gti 1990
    Canada
    My pump was brand new and it whined alwaya. its right in front of the rear drivers wheel so not far from you.
  6. Re: mk2 golf gti 1990
    brighton
    apparently the temp gauge at normal is halfway up mine rises to first line when it gets to secound thats when it normally stalls sometimes before basically no long journeys but running from cold road animal
  7. Re: mk2 golf gti 1990
    Canada
    The more you explain this the more i think electrical. the needle should be straight up whrn tunning at normal. does the LED blink in the temp gauge at all?
  8. Re: mk2 golf gti 1990
    brighton
    yes it does initially then stps but needle still does not go up to centre
  1. 1990 Golf GTi cabrio misfiring
    By Dave Clark in forum Archive posts
    Last Post: 04-06-2007, 07:53 PM
  2. 1990 Mk 2 Golf 1.3 Gearbox probs
    By radcliffe in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-03-2007, 12:23 PM
  3. golf mk3 cabriolet
    By littlebugger in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-11-2006, 02:27 PM
  4. vw golf 1990 clipper cold start nightmare!!
    By chally34uk in forum Archive posts
    Last Post: 09-01-2006, 12:19 PM
  5. 1990 GOLF CLIPPER HELP!!
    Last Post: 05-12-2005, 08:54 AM
