Thread: service indicator
Results 1 to 8 of 8
  1. service indicator
    May 2007
    hi i've just bought a 1998 passat tdi 1.9 se could anyone help me with what the services indicator should say when i start up car came with no handbook currently says insp flashing for about 30secs then goes out is that what its supposed to do also is there anywhere i can get a handbook maybe pdf format . thanks
  2. Re: service indicator
    Oct 2005
    It means you need a service
    It'll either say INSP or OIL - the INSP is a major service, the OIL is an oil service.
    Handbooks, as much as it hurts me to say, are available on eBay - be careful what you buy though.
  3. Re: service indicator
    May 2007
    hi service has been done how do you reset the thing. thanks
  4. Re: service indicator
    Oct 2005
    Follow the instructions in this post; https://www.vwaudiforum.co.uk/forum/s...ad.php?t=13480
  5. Re: service indicator
    May 2007
    thanks for replies one other question? how long are the service intervals i've have not had a vw before so not sure how long between each oil change? thanks
  6. Re: service indicator
    Oct 2005
    Oil change is recommended every 10k, but quite a lot of owners do this every 5k.
    Service intervals are 10k unless you're on longlife servicing. I'd say you're on normal 10k services as the car is relatively old.
  7. Re: service indicator
    May 2007
    what year did longlife service come in ?
  8. Re: service indicator
    Oct 2005
    See this from VW;
    http://www.volkswagen.co.uk/services...service_regime
    In particular, the link to the PDF - "To find out more about....... "
  1. Service Indicator Reset
    By pbriggs in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-04-2018, 12:47 PM
  2. Does resetting service indicator set service regime to fixed?
    By golfgtdude in forum Golf MK5 - 2004 - 2009
    Last Post: 01-10-2007, 06:38 PM
  3. Service indicator reset
    By devin in forum Audi A4 - Archive Topics
    Last Post: 26-05-2007, 10:23 PM
  4. Bora TDi Service Indicator
    By Ewan151 in forum Bora - 1998 - 2005
    Last Post: 07-09-2006, 01:05 PM
  5. Resetting service indicator 2002 A4 1.9 Tdi 130
    By spannerstrangler in forum Chat - Completely Off Topic
    Last Post: 05-07-2006, 08:54 PM
