Hiya, new member here - just ordered a new Passat 2ltr GT pearl black estate with the 150dsg.
I have added the discovery pro nav (£815) as an option, but wanted to check how it actually works and connects to the Internet to use google earth, weather etc...
There is quite a lot of conflicting information online ranging from:
1) it has a hidden sim card, and connects that way
2) it uses rsap Bluetooth (my iPhone doesn't )
3) it can connect to any wifi / mifi hotspot.
I have an iPhone, so rsap isn't an option, so I am hoping it is either number 1 or 3.
If you can set it up to connect to any wifi, I guess I will just use one of these little wifi hotspot mifi things with a seperate SIM card ??
Is the built in SIM card worth adding to the cars build - any benefit of doing this?
Just wondering what anyone uses, and if possible can you drop me a download link for the manual
Also, does the unit play nicely with an IPhone6, and play media from it, or does everyone use the SD card option instead?
I see that the new Skoda Superb will be Car Play enabled, and it appears to have the same hardware, so possibly an update of firmware to the Passat will do the trick? Any thoughts?
Thanks guys
Jim
