Thread: Will these fit with work
Results 1 to 9 of 9
  1. Will these fit with work
    Mar 2015
    Cardiff
    Item specifics
    Condition: New Rim Material: Alloy
    Bolt Pattern: 5x114.3 Rim Width: 9.5 F/11 R
    Hub Bore: 73.1 Rim Diameter: 19
    Rim Brand: ZEDD Offset: 12 Front, 15 Rear
    Rim Structure: One Piece Number of Bolts: 5
    They will be with hub adaptors which adds 20mm
  2. Re: Will these fit with work
    46 Post(s)
    9.5J front and 11J rear even without considering the uber low offset they'll not fit.
    Bolt pattern is wrong too.
  3. Re: Will these fit with work
    Mar 2015
    Cardiff
    Quote Originally Posted by Chris View Post
    Why wont they fit then?? thats what the hub adaptor is for to change the pattern from 5x112 to 5x114.3
  4. Re: Will these fit with work
    46 Post(s)
    They're far too wide, the arches on the a6 aren't wide at all. A 9J rim with ET33 won't fit, I've tried.
  5. Re: Will these fit with work
    Mar 2015
    Cardiff
    were they hitting the inside or out side
  6. Re: Will these fit with work
    46 Post(s)
    They were too close to the arch and would've caught on full lock.
  7. Re: Will these fit with work
    Mar 2015
    Cardiff
    What about rolling them or flaring them
  8. Re: Will these fit with work
    46 Post(s)
    That's not something I'd do as its a lot of work and to go back to stock you'll pay. But whatever floats your boat I suppose.
  9. Re: Will these fit with work
    Mar 2015
    Cardiff
    nar i don't want to be doing it that much. i will choose different wheels, thanks for the help tho
  1. MFSW retro fit radio controls won't work
    By Norfolk-Boy in forum VCDS - Help Requests
    Last Post: 31-12-2011, 11:26 AM
  2. Replies: 22
    Last Post: 23-02-2011, 12:26 AM
  3. Parking Sensors work then don't work
    By fabusy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-02-2010, 10:03 PM
  4. Springs Will they fit/work?
    By MickeyBravo in forum Polo - Derby - Lupo - Fox
    Last Post: 11-03-2009, 07:59 PM
  5. How Much Work Would It Be To Fit...
    By Stuart_B in forum Golf MK4 - 1999 - 2004
    Last Post: 10-03-2008, 12:03 AM
