Thread: Looking for an a4 avant :)
  1. Looking for an a4 avant :)
    Apr 2015
    United Kingdom
    I'm looking to purchase an A4 avant 2 litre TFSI quattro as my current car (skoda fabia vrs 6y) is getting a bit small with all these children.
    so I'm looking for any advice in relation for what to look out for when buying and any common faults / problems For this car.
    really can't afford a lemon right now so any help is greatly appreciated.
    many thanks!
  2. Re: Looking for an a4 avant :)
    May 2012
    Everywhere
    308 Post(s)
    A B7 has poor room in the back .
  3. Re: Looking for an a4 avant :)
    Apr 2015
    United Kingdom
    Thanks for your reply,
    poor compared to a b6?
    I have a large toddler soon to be in a booster and a newborn.
    how bad can it be?
  4. Re: Looking for an a4 avant :)
    Nov 2008
    Farnborough Hants
    I have a 2.0 tfsi se non quattro. I have 2 kids 9 and 12 yrs plenty of room in the back for them.Things to watch for, check the cam belt has been done every 75,000 miles or 5 yrs. full service history, coil pack recall is done. only other things I've had on mine is turbo recirculation valve replaced and it needs suspension arms on the front . other than that its been a good car now on 101,000 miles and going fine.
  5. Re: Looking for an a4 avant :)
    Jul 2014
    I would add the PCV is a major issue (and associated breather if you have the valve) - when it fails it not only causes bad idling, excessive oil consumption, but also can cause other seals to go as you get boost pressure where you shouldn't (so I had a rear main oil seal change and my oil sump sealant had to be replaced - both costly). Its cheap to replaced but its the consequential damage thats a problem. Simple tests you can do for this are to see how difficult the oil filler cap is to remove and to try to blow down the hose running from the manifold to the PCV. So check the belly pan for oil leaks if possible or around the components.
  6. Re: Looking for an a4 avant :)
    May 2012
    Everywhere
    308 Post(s)
    Quote Originally Posted by windyj View Post
    It's well known it's snug in the back , a few comments I found.
    Yes, the lack of back seat room concerns me. I don't often carry passengers back there, but when I do...
    An A6 would have more room but it's out of my price range.
    I drive a MK6 GTI. I have more rear leg room than the A4 has.
  7. Re: Looking for an a4 avant :)
    Jul 2014
    Yep, its defo snug in the back with adults. I've got a toddler so normally it's no problems or would be doing short trips with adults so again no problems. But the other day I did do a hour trip with the grandparents on board as well it was pretty snug. It was fine but it did get a touch uncomfortable for them - the taller was 5'10". I can see that 6'+ would find it uncomfortable if in the car for long.
  1. Goodbye 2007 RS4 Avant, Hello 2010 A6 le mans avant
    By bigsteve1635 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-06-2015, 05:49 PM
  2. Windows on 2006 A6 avant vs A6 avant sline
    By sareenv in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-01-2015, 04:29 PM
  3. Audi A4 Avant written off - gutted! Thinking of an A6 Avant. Views?
    By Ghaudi81 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-06-2014, 04:43 PM
  4. Can seats from a 2004 onwards A6 Avant be modified to fit a 2003 A6 Avant?
    By chrisroffey in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-07-2009, 05:47 PM
  5. A4 avant S-Line EXT vs standard a4 avant
    By lxbevi in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-08-2008, 10:27 AM
