Thread: Oil temperature gauge parts.
  1. Oil temperature gauge parts.
    OK, having had to replace my instrument cluster, all dials including the voltmeter work find. However, the oil temperature doesn't, not having the connections since my old cluster didn't have the oil temp gauge.
    I was browesing ebay and notive they do have an oil temp sensor/ sender replacement that just screws into the oil cooler housing. Great I could get this working, but, I could not find the 4 pin connector that clips into the instrument panel to operate the gauge, the wire from that to whatever it is called the clips on the sensor itself.
    Does anybody know what these are actually called or more hopfully where i can buy them form.
    Thanks.
  2. Re: Oil temperature gauge parts.
    Sep 2013
    neath,wales
    Sensor is 049919563b,its a one pin sensor,the connector is a female spade.The 4 pin connector is 4d0972623,the feed wire for the gauge goes to pin 1,the bottom pin.
    Have a look at your dash loom,there may be a stray blue/white wire,this will be the temp sensor feed,with a corresponding blue/white wire close by the oil pressure switch wire in
    the engine loom.If not,try running a wire from the 4 pin up through the ecu box,along the loom into the engine bay,and onto the new sensor.If this doesnt work,then its time to
    hunt down the relevant pins on the ecu.
    on ebay theres a 4 pin connector from a golf alarm system for sale,same part number as for the A4 dash,so it will fit.
  3. Re: Oil temperature gauge parts.
    Quote Originally Posted by cidrox50 View Post
    Wow, excellent reply.
    Thanks for that.
  1. Oil Temperature Gauge fluctuating A4 2.4 V6
    By surferireland in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-10-2014, 10:54 AM
  2. Oil Temperature gauge not working
    By patf0 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-06-2014, 09:01 AM
  3. Temperature gauge reading lower than actual temperature
    By garymansell in forum Golf MK3 - 1993 - 1999
    Last Post: 24-08-2009, 04:29 PM
  4. Question Oil pressure and temperature gauge
    By derrick2553 in forum Golf MK4 - 1999 - 2004
    Last Post: 14-07-2008, 03:15 PM
  5. Coolant temperature gauge & oil warning lamp
    By wblatchley in forum The Commercial Range
    Last Post: 07-08-2007, 10:05 AM
