Thread: Power steering failure??
Results 1 to 10 of 13
  1. Power steering failure??
    Mar 2015
    pelsall
    My question is, can this randomly occur or is there a cause?
    Car went in for front drivers side bearing. The Mrs got a phone call saying that as the mechanic pulled the car out of the garage, the power steering failed and found it very heavy to turn.
    Is this a common problem on a 1.6 manual 2004 model?
    Somewhere along the lines a "torque converter was mentioned?? I'm lead to believe this is only on an automatic car?
    Quotes of £900 for new one or £2-300 for second hand one was also said. I will be ringing in morning to clarify but it's just bugging me atm.
    Any help/guidance would be appreciated...
  2. Re: Power steering failure??
    Pembrokeshire
    22 Post(s)
    sounds like a load of billy to me. pas can fail but rarely does. not sure if yours is hydraulic or electric, but neither system uses a torque convertor. as you say, auto boxes use that.
    2 1 0
  3. Re: Power steering failure??
    Mar 2015
    pelsall
    As I say, he spoke to the Mrs so she ain't too sure what was said but she wouldn't have plucked "torque converter" out of the air. But I saw one here about a new rack would cost around 900, maybe that?
    Think I may fetch car and get 2nd opinion.
  4. Re: Power steering failure??
    Aug 2011
    Meath
    Get the car and check if it's electric or hydraulic ps. If its hydraulic check the belt in tight and that it has fluid, start the car and check if the pump is sticking. An electric pump will require plugging in the car after you rule out a fuse.
    2 1 0
  5. Re: Power steering failure??
    Mar 2015
    pelsall
    Quick update, had a little chat to mechanic in-between my work, and he says "torque converter electronic sensor" which is built into the steering rack...
    Does this make sense to anyone?
  6. Re: Power steering failure??
    Pembrokeshire
    22 Post(s)
    its an electric system, so basically a motor built into the rack. normally really reliable but anything can fail. i would get another opinion. also try starting the ca and just letting it run for a bit to charge the battery. obvioulsy being electric it need lots of power, so if they have falttened the battery at all ??
    1 1 0
  7. Re: Power steering failure??
    Mar 2015
    pelsall
    Yeah I was going to get it back. Get it towed, or will it be OK, only about 5 mile drive, just with heavy steering. Cheers
  8. Re: Power steering failure??
    Pembrokeshire
    22 Post(s)
    are you in the AA ? or rac or other ??? get them to collect and diagnose whilst tey are at it.
  9. Re: Power steering failure??
    Mar 2015
    pelsall
    Yeah in aa, so just pull up down road and say it broke down?
  10. Re: Power steering failure??
    Pembrokeshire
    22 Post(s)
    no, i would get the AA to go to the garage if they will. it might be a legit failure, or they have pulled the fuse out.
    2 1 0
  1. Please Help Power steering failure
    By chazcrute in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-02-2014, 02:49 PM
  2. Power steering failure
    By alang498 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-06-2012, 11:08 PM
  3. Power Steering failure
    By jim77 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-02-2010, 05:17 PM
  4. Power Steering failure
    By chuileog in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 16-03-2009, 09:08 AM
  5. Please Help Power Steering failure
    By jimat57 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-07-2008, 09:34 PM
