Thread: ECON light for air conditioning.
  1. ECON light for air conditioning.
    Dec 2008
    Hi my econ light has been permanently on for a while now, due to the nice weather I thought I finally sort it. I took it to a garage and without even looking at it they diagnosed it stating it needed a new compressor.
    i then went on the internet and read treads about the aircon high pressure switch (g65), i managed to get my car onto VAG COM and the error code I had id
    00819- high pressure sensor (g65)
    07-00 signal too low
    also to note that I tried recharging my air con at a specialist and they stated it had hardly any feon,they could not recharge it as the aircon was not circulating (econ light)
    my question is if it is the sensor then do i have to clear the fault code after the new sensor has been fitted or does it self clear?
    also anyone know were i can get a sensor from and £££ and if anyone knows the part number (2002 audi a4 1.9 tdi awx)
    im guessing stick to genuine part
    thanks in advance
  2. Re: ECON light for air conditioning.
    Dec 2009
    southampton uk
    I would get a genuine one.You will need to clear the fault
  3. Re: ECON light for air conditioning.
    Aug 2011
    fakenham
    get one from audi or vw, it will cost about 60£, easy to fit..
  4. Re: ECON light for air conditioning.
    May 2007
    Under the Forth Bridge
    8e0 959 126. Part number for thrust sensor/pressure switch. Easy fix - even easier if you loosen off the passenger headlight and slide it forward for access. Loads of threads on here about replacing.
    Current : B6 (54) 1.9tdi Quattro Sport Avant (250k and counting), 8L (02) A3 1.9tdi Quattro Sport (5dr) (130k and counting) VW Touran 2016 2.0tdi Family SE (don't ask!)
    Previous : B6 (03) 1.9tdi Quattro SE, 8L (03) A3 1.9tdi SE (5dr)
  5. Re: ECON light for air conditioning.
    May 2007
    Quote Originally Posted by miniredcooper View Post
    Forgot to say - don't forget a new sealing o ring for the sensor part number 7H0 820 896 dirt cheap and frequently forgotten.
    two 17mm spanners needed for the sensor job and torx drivers/sockets to release the headlight.
  1. Air Con - ECON help
    By markiwill83 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-07-2014, 06:44 PM
  2. kl.15 fuse constantlt blowing - also econ light has come on and air con not working
    By billyfurey in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-09-2011, 06:32 PM
  3. Air Conditioning Unit, Hot air on drivers side, cold on passenger
    By pflangan in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-06-2011, 06:38 PM
  4. ECON Light - Air Con
    By biker_billy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-08-2009, 07:54 PM
  5. No Back Light on Air Conditioning Display
    By tp5harp in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-10-2008, 06:33 PM
