Thread: Injector cleaner for PD engines. (B 5.5, 1.9 TDI 130 AWX)
Results 1 to 10 of 12
  1. Injector cleaner for PD engines. (B 5.5, 1.9 TDI 130 AWX)
    Jan 2009
    Does anyone have experience of injector cleaning on PD engines (or even if it is ever necessary)? I am interested in getting the best performance and economy but am concerned not to degrade the seals with powerful solvent. Many thanks.
  2. Re: Injector cleaner for PD engines. (B 5.5, 1.9 TDI 130 AWX)
    Pembrokeshire
    22 Post(s)
    add a pint of petrol to a full tank of diesel, and make sure she is serviced up with good clean filters, the timing must be spot on and best to fit a new injector harness if its done more than 100k miles on it. injector seals are easy enough to do and make a big difference if they are past their best, and also gives you a reason to set the injector rockers tolerances.
    2 2 0
  3. Re: Injector cleaner for PD engines. (B 5.5, 1.9 TDI 130 AWX)
    May 2012
    Everywhere
    308 Post(s)
    Add 250 ml of JASO FB spec 2 Stroke to a tank of diesel .
    New injector loom after just 100 k ? ?
    1 1 0
  4. Re: Injector cleaner for PD engines. (B 5.5, 1.9 TDI 130 AWX)
    Pembrokeshire
    22 Post(s)
    yes, there are 3 or 4 pre and post injections of fuel, and the main injection. as the loom degrades you start to lose these tiny injections that get the burn going and keep it going after the main power injection. its quite remarkable looking at a new and old loom on a scope, especially when the engine is running fine, but a new loom does make a difference. its a cheap price to pay to keep an engine in tip top running order, yet is often overlooked.
    1 1 0
  5. Re: Injector cleaner for PD engines. (B 5.5, 1.9 TDI 130 AWX)
    May 2012
    Everywhere
    308 Post(s)
    I don't doubt it , it's a hot harsh environment inside a cylinder head . Just that most encounter a misfire around 250k requiring loom replacement.
    Mine made very good power on a dyno at around 165k so I'm not looking to replace anything except a due cambelt kit , water pump and aux belts .
  6. Re: Injector cleaner for PD engines. (B 5.5, 1.9 TDI 130 AWX)
    Mar 2011
    S/land UK
    I`ve always understood you don`t put petrol in modern direct injection diesels, ok for the old idi and tractors.
    Use Archoil AR 6600 or BG 244 both good
  7. Re: Injector cleaner for PD engines. (B 5.5, 1.9 TDI 130 AWX)
    Pembrokeshire
    22 Post(s)
    not in a common rail , no, but a pd is a different matter. in fact the most petrol you can add to a pd without having to drain the tank is 25 %.
  8. Re: Injector cleaner for PD engines. (B 5.5, 1.9 TDI 130 AWX)
    Mar 2011
    S/land UK
    I couldn`t bring myself to do it
  9. Re: Injector cleaner for PD engines. (B 5.5, 1.9 TDI 130 AWX)
    Pembrokeshire
    22 Post(s)
    thats what vw advised. remember the toyotas that top gear took to the north pole, they ran on 50% petrol.
  10. Re: Injector cleaner for PD engines. (B 5.5, 1.9 TDI 130 AWX)
    Jul 2007
    glasgow
    35 Post(s)
    Paraffin is also used in cold weather with diesel, usually its a gallon of petrol to a full tank of diesel
    An Italian decoke does wonders, put it in 2nd gear and travel for a few hundred yards down a road just under the red revs
  1. Help please N75 problems TDi 130 AWX
    By Metallurgix in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-05-2012, 08:29 PM
  2. A4 1.9 TDi 130 AWX not getting upto temp
    By chrisvrscrx in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-04-2012, 06:22 AM
  3. vacuum hose diagram for a TDI 130 AWX
    By vwnige in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-03-2012, 11:57 AM
  4. Question Mk3 Golf 81kw TDI Injector Cleaner
    By albert81 in forum Golf MK3 - 1993 - 1999
    Last Post: 07-09-2010, 10:40 PM
  5. Different 1.9 tdi 130 engines
    By Dave Avant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-06-2009, 03:30 PM
