Thread: STOP - Check Coolant!
  1. STOP - Check Coolant!
    Grant Guest
    '99 GT TDI 115bhp
    When we start the car from cold the dash nearly always comes up with STOP - Check Coolant. If you drive about 100-200 yards (out of our estate basically) this goes off and its fine until its restarted from cold-ish again.
    I've checked the coolant and the level is fine, if I squeeze the hoses going to and from the rad the water moves about in the expansion bottle so I'm assuming its cycling round correctly, and the car runs at spot on 90 degrees when it gets up to temp
    Any ideas?
  2. Re: STOP - Check Coolant!
    nuneaton
    i had the same put a extra cup of water in the header tank
  3. Re: STOP - Check Coolant!
    Mar 2007
    Had the same problem on mine. Replaced the expansion tank and cap at a cost of around £15 and a 15 min job to do yourself. No problems since. Tank has level sensor built into it so assuming that was faulty although no problem showed in a fault scan with vagcom.
  4. Re: STOP - Check Coolant!
    Aug 2007
    Birmingham
    Quote Originally Posted by Grant View Post
    '99 GT TDI 115bhp
    Any ideas?
    The water must be stone cold when you check it - it'll start rising when the pressure builds up after you start the engine
    Black Magic 53-plate Mk1 Leon TDI Cupra PD150 (daily drive)
    Grey Nissan 200SX S13 (weekend car - currently being rebuilt, was 264 BHP at the hubs)
  1. Stop those leaks...
    By Diarmuidsaysdance in forum Beetle 2000-
    Last Post: 07-12-2009, 12:35 PM
  2. STOP on display??????
    By Big G in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-10-2007, 12:09 PM
  3. Warning! Check coolant! Golf GTi Mk4
    By rickgti in forum Golf MK4 - 1999 - 2004
    Last Post: 07-08-2007, 03:31 PM
  4. check coolant STOP
    By pnuckched in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-11-2006, 04:14 AM
  5. Check coolant warning but level fine
    By brad1 in forum Archive posts
    Last Post: 28-07-2006, 02:37 PM
