Thread: facelift 7 speed DSG clunky at slow speed
  1. facelift 7 speed DSG clunky at slow speed
    Jan 2014
    Nottingham UK
    As is the norm, more often than not these days with early morning city driving you find yourself in slow crawling traffic. I have noticed that when the car (2WD Ultra Sline) is crawling along the gearbox will normally be in 3rd but then as you slow to a stand still it can often be quite a notchy gear change down to 2nd and sometimes from 2nd to 1st can be very clunky. Going up the gearbox, cruising or when coasting mode is active it is seamless and you struggle to tell that it is changing gear. I often use the Eco setting around town so I am not sure if the other settings may help to reduce the issue.
    Do others find this same issue and is there anything you can do or a software upgrade available?
  2. Re: facelift 7 speed DSG clunky at slow speed
    May 2013
    Wisbech
    8 Post(s)
    It is common problem on s-tronic gearbox and indicates problems with it, if you have still warranty i would be in dealers if i was you .
  3. Re: facelift 7 speed DSG clunky at slow speed
    May 2014
    Bath, UK
    That's probably a mechatronic unit needing replacing.
  4. Re: facelift 7 speed DSG clunky at slow speed
    May 2013
    Wisbech
    8 Post(s)
    Mechatronic or clutches in gearbox should solve a problem but I know situation where this didn't help and dealer swap whole gearbox.
  5. Re: facelift 7 speed DSG clunky at slow speed
    Drigmot Guest
    More often you find dealers replace gearboxes because they don't have a qualified technician to replace the clutch. If you aren't on LUK's list of approved technicians then you can't buy the clutch so it becomes a gearbox replacement.
  1. Question Noise at slow speed steering
    By Jack Lomas in forum Chat - Anything with wheels
    Last Post: 20-04-2015, 10:24 AM
  2. 7 speed DSG slow gear changes
    By andyb2004 in forum Touran - Sharan - Caravelle
    Last Post: 24-12-2014, 01:28 PM
  3. Question Idle speed too slow / stalling
    By ollyrag in forum Golf MK4 - 1999 - 2004
    Last Post: 16-06-2014, 07:59 PM
  4. 1-4 Tsi 122 ps 7 speed DSG or 2-0 140ps 6 speed DSG
    By mr pastry in forum Golf MK6 - 2009 - 2013
    Last Post: 22-04-2009, 08:26 AM
  5. Idle Speed Very Slow?
    By Guffbert in forum Golf MK4 - 1999 - 2004
    Last Post: 19-04-2009, 10:27 PM
