Thread: Sharan dual mass flywheel
Results 1 to 10 of 15
  1. Sharan dual mass flywheel
    Sep 2007
    Just had my sharan serviced. Used VWTechnics near Cambridge - I can recommend them. I mentioned that the engine was idling unevenly and that pulling away in 1st/2nd gear at low revs sometimes was a bit "jerky". Since they come and pick up the car and deliver it back they had the perfect chance to experience the symptoms.
    Anyway it appears that there is a problem with the dual mass flywheel being seized and it will need replacing. I had a bit of a shock when it came in at £600 + labour. I asked if it had to be done now and I was told that is wouldn't actually harm the engine to drive it like this for a bit longer (the symptoms are not too severe and reduce when the engine is warmed up). Is that really the case?
    I was wondering if others have seen this problem and if there are cheaper options - are non genuine VW parts OK? Do you think I can source the part myself and ask the garage to fit it?
    thanks
    SD
  2. Re: Sharan dual mass flywheel
    Bristol
    Quote Originally Posted by soup_dragon View Post
    thanks
    SD
    year ?
    mileage?
    Engine code ?
    £600 for dual mass flywheel, your kidding me right
    MK5 Golf TDI 2.0ltr GT Sport in Black
  3. Re: Sharan dual mass flywheel
    Bristol
    a quick look on gfs and ..........
    https://secure.gsfcarparts.com/shop/results.asp
    FLYWHEEL-DUAL MASS SHARAN 1.9TDi £230.00
    I know which id go for
    Probably from the same factory as a OEM one !!!
  4. Re: Sharan dual mass flywheel
    Sep 2007
    The model in question is a 2001 Sharan 1.9TDi (7M9). Engine type is AUY.
    Actually I'm a little confused about exactly what is included in the quote. The garage guy implied that the flywheel, clutch and pressure plate are replaced as a unit because it makes sense to do them all while you have the engine apart. The £230 quote above is for the flywheel - but I guess that does not include the clutch and pressure plate, right?
  5. Re: Sharan dual mass flywheel
    Dec 2006
    Manchester
    It's cheap if it does!
    1.9 tdi PD 100 Bora
    110cc pitbike, 4 speed semi-auto
    110cc Off road buggy, 4 speed semi-auto
  6. Re: Sharan dual mass flywheel
    Ballycastle, Northern Ireland
    The dual mass fly wheel was replaced free of charge on my Alhambra through a safety recall about 2 years ago. I got a letter from Seat which said something about a fire hazard. Hope this is of use.
  7. Re: Sharan dual mass flywheel
    Mar 2007
    coventry
    ok dual mass flywheel is around 230 from gsf clutch kit is aroun 95 plus vat try euro for parts and i have got a price for both that comes to 288
    then get cheaper garage to fit
    no matter how you try you always come back to what you first started
  8. Re: Sharan dual mass flywheel
    Feb 2007
    i had a new clutch fitted and not flywheel bad move ! replace them both my sharan runs like a dream now got my clutch flywheel kit of a power seller on ebay it was cheaper and got a local guy to fit it
  9. Re: Sharan dual mass flywheel
    Quote Originally Posted by cbrpaul View Post
    Yep... theres only one factory in Europe that makes em
    2019 Urus, 2020 RS7
    2014 RS6, 2018 RS5, 2016 RS3, 2019 RS3
    2011 RS5, 2008 S5 V8
    2007 A4 2.0, 2008 Passat 2.0 TDI
    2005 Bora 1.9 TDI, 2000 Bora 1.6 , 1989 Polo 1.4
  10. Re: Sharan dual mass flywheel
    Quote Originally Posted by FatherTed1 View Post
    Was all 2.0 VAG flywheels, + maybe a few others. Was because they caught fire occasionally!! The back of the flywheel was magnesium with a clip behind it that if it came loose, could spark and ignite it!!!
    2019 Urus, 2020 RS7
  1. Dual mass flywheel problems
    By Gully in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-09-2007, 11:28 AM
  2. Dual Mass Flywheel Fault?
    By TDiBoraSam in forum Bora - 1998 - 2005
    Last Post: 02-09-2007, 07:43 PM
  3. dual mass flywheel
    By jimbob in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-06-2007, 01:22 PM
  4. Dual Mass Flywheel
    By Richardm in forum Passat - Archive Topics
    Last Post: 27-03-2007, 02:54 PM
  5. How much should a new Dual Mass FLywheel cost?
    By kieranpage in forum Archive posts
    Last Post: 22-01-2007, 02:13 PM
