Thread: Lower ball joint and suspension arm concern
Results 1 to 10 of 12
  1. Lower ball joint and suspension arm concern
    Jun 2012
    Wiltshire
    Hi All,
    I have recently replace all suspension arms on my a4 from a kit I bought on ebay.
    All items fit snug to the car bar the lower front control arm. There is a gap between the nut and end of the conical section that attaches to the joint?
    When fitted the bolt was tight but when I lowered the car onto the suspension the joint traveled further and there is now a gap between the nut and hub assembly?
    This doesn't look right and I am not sure what I have missed?
    Any help appreciated!
  2. Re: Lower ball joint and suspension arm concern
    Aug 2011
    Meath
    Do you have a vernier calliper? Measure the other side as there's different sizes and somebody might have put a hub from a scrapyard on it. That cars not safe to drive put in the old one until you get a replacement. Post a link to the kit you bought.
  3. Re: Lower ball joint and suspension arm concern
    Jun 2012
    Wiltshire
    Hi thanks for responding I will be chucking the old ones back in now, I don't think the hubs have been changed given the look of it and how tough some of those bolts were to come out. Both sides are the same and the kit is this one
    WISHBONE SUSPENSION ARMS KIT SET FRONT AXLE LH RH AUDI A6 4B C5 1.8-3.7 97-01 | eBay
  4. Re: Lower ball joint and suspension arm concern
    Aug 2011
    Meath
    Mate those kits are bovine excrement return them and start a complaint with ebay immediately. If you can't afford to do it all at once do the bottoms first then the tops. Those kits you linked to are made from the tinsel in old embassy cigarette packets
  5. Re: Lower ball joint and suspension arm concern
    Jun 2012
    Wiltshire
    thought it looked to good to be true, have just ordered some new parts from eurocarparts these ones best fit. Thanks for your help!
  6. Re: Lower ball joint and suspension arm concern
    somerset
    8 Post(s)
    Sorry to rub salt etc, but buy cheap, buy twice. If I was doing the job myself I would go genuine Audi parts or if that is out of range I believe Llemforder are good as are meale, I have used the e bay ones before and they do last......... For about a year, it's an *** of a job, and one you only want to do once. If you buy from TPS you will get genuine Audi, or if that's too dear, try GSF or Euro car parts. If it was me with my pair of B6 1.8T's I would probably go for TPS. The genuine ones should last over 100k.
  7. Re: Lower ball joint and suspension arm concern
    6 Post(s)
    Quote Originally Posted by Doctle Odd View Post
    Excellent description. The structural integrity of the Embassy foil wrapper still out-performs the Ebay part!
    Only fit Meyle HD, Lemforder, etc. It's a sod of a job to do, so it never ceases to amaze me why some people cut corners. These things are critical and I certainly wouldn't want one to fail at speed.
    2017 A4 Allroad Quattro Sport 3.0 TDI 272PS, (59k)
    2016 BMW i3 REx (80k)
  1. Lower arm ball joint sizes.
    By Mudchute in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-01-2014, 07:36 AM
  2. suspension arm ball joint dust/grit covers - where from ?
    By Golf tdi Hal in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-07-2013, 09:55 AM
  3. Lower Ball joint wear
    By skymaster in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 10-07-2012, 01:34 PM
  4. Question Spilt CV joint covers and suspension arm ball joint replacement
    By chekers in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 24-10-2011, 02:51 PM
  5. Please Help Removing lower ball joint on Mk4 Golf
    By steve richards in forum Golf MK4 - 1999 - 2004
    Last Post: 25-02-2011, 12:06 PM
