Thread: How easy is it to change the front speakers?
  1. How easy is it to change the front speakers?
    Sep 2007
    North Wales
    How easy is it to change the front speakers in my Audi 80 Estate?
    Many thanks.
    Coastie.
  2. Re: How easy is it to change the front speakers?
    i think the whole dash has to go off, and thats a lot of work. i know that from last year when changed the heater radiator.
  3. Re: How easy is it to change the front speakers?
    Finjamin Guest
    Hi coastie.
    Assuming the speakers are in the same place as the non-estate version (ie: set into the top of the front dash) apparently all you have to do is push them downwards with your hand and rotate them, and then unscrew the little fixing screws. I havent tried this on mine, but i just read it barely 10 minutes ago on this forum! Hope it helps.
    Finn
  4. Re: How easy is it to change the front speakers?
    Sep 2007
    North Wales
    Hi Finn.
    I'll try that when I'm next off work, many thanks.
    Best wishes.
    Coastie.
    P.S. Yes, the speakers are in the same place, I'm sure.
  5. Re: How easy is it to change the front speakers?
    Sep 2007
    North Wales
    Have had the grilles off, mine were just prised off with a couple of stickies underneath, then unscrewed one screw and the speaker slid out. Now to find where I can buy two more! (I didn't blow them!!!)
  6. Re: How easy is it to change the front speakers?
    paul20v Guest
    hi
    i used 4" infinity s they sounded nice and clear
  7. Re: How easy is it to change the front speakers?
    Sep 2007
    North Wales
    Quote Originally Posted by paul20v View Post
    hi
    I've just bought a second hand pair off e-bay, but I'll bear that in mind should the go again. Thanks.
  1. 6.5" front speakers
    By mrjolly in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-12-2007, 08:38 AM
  2. How easy or difficult to...change a steering wheel (full descriptive titles help!)
    By A6_JAck in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 14-09-2007, 11:35 AM
  3. Is it easy to change rear brakes pads on A3
    By A Tdi in forum Archive posts
    Last Post: 01-09-2007, 06:02 PM
  4. Front Door Speaker - How to change it, disconnect it ....aaaah
    By sbuk73 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-08-2007, 09:17 AM
  5. golf mk1 front speakers
    By NicholasP in forum Golf MK1 - 1974 -1984
    Last Post: 15-02-2007, 09:09 PM
