Thread: A4 B5 Avant rear shock absorber removal
  1. A4 B5 Avant rear shock absorber removal
    Aug 2008
    Chelmsford England
    My shock absorbers need replacing. I understand the mechanics of this operation and have the tools/clamps etc, but how do I remove the trim at the rear to get at the top bolts please.
    Matty
  2. Re: A4 B5 Avant rear shock absorber removal
    Sep 2008
    6 Post(s)
    Quote Originally Posted by amatty View Post
    Matty
    Read this: B6/B7 A4: Suspension Removal and Install
    Its for B6, but B5 exactly the same.
    2016 BMW i3 REx (80k)
  3. Re: A4 B5 Avant rear shock absorber removal
    Aug 2008
    Chelmsford England
    Have replies from other sources now thanks but they are for b6 or B7 cars which are completely different from my 1.8 A4 B5 avant.
    All I want to know please is how to remove the trim inside the vehicle so that I can get at the top shock absorber mountings from inside the rear.
    Matty
  4. Re: A4 B5 Avant rear shock absorber removal
    131 Post(s)
    1973 Post(s)
    We have a 1998 A4 Avant we use as a courtesy car and we had to do rear dampers a few months back. Whenever we have to do rear dampers on an 8D estate, I cringe because getting those trims out is awful, they are held by inaccessible spring loaded clamps that need the opposing forces of two elephants to pull apart and when they do, the clamp and a section of the trim stay in the slot and the trim is left with a jagged hole in it....
  5. Re: A4 B5 Avant rear shock absorber removal
    Pembrokeshire
    22 Post(s)
    i remember doing a passat, about 95 vintage a while back. 10 mins to do both shocks, 3 hours to remove and replace the trim to get to the top bolts. seriously, a proper ball ache of a job.
  6. Re: A4 B5 Avant rear shock absorber removal
    131 Post(s)
    1973 Post(s)
    I've done a few type 35 and 3A rear dampers and it drives me mad that you can get to one bolt on each top mount but not the other so it's hours of trim hell.
  1. rear shock absorber replacement
    By bert3d in forum Passat CC
    Last Post: 04-06-2015, 11:03 AM
  2. Rear shock absorber replacement.
    By amatty in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-04-2015, 09:50 PM
  3. Signs of oil on rear shock absorber
    By gianton in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-06-2013, 06:18 PM
  4. rear shock absorber failure
    By gtv160 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-03-2011, 06:15 PM
  5. Touran rear shock absorber diagram
    By jrross in forum Touran - Sharan - Caravelle
    Last Post: 23-09-2010, 10:05 PM
