Thread: mk3 golf OBD port
Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 75
  1. Re: mk3 golf OBD port
    Aug 2011
    Meath
  2. Re: mk3 golf OBD port
    Aug 2011
    Meath
    2nd link is for a map showing members of this site with VCDS they will scan your car. Just look for someone near you and send them a private message
  3. Re: mk3 golf OBD port
    Mar 2015
    Ayrshire, Scotland
    Engine temp 80oC
    1st fast Idle 2450-2850
    CO 0.58 Max - 0.30
    HC 51 Pass
    Lambda 1.059 Fail - 0.970 - 1.030
    2nd fast idle
    CO 0.54 Fail max limit 0.30
    HC 77 pass
    Lambda 1.072 fail
    natural Idle
    CO 0.36 Pass max limit 0.50
    Since that test result I changed the lambda probe for a new NTK one, and it failed again on High CO level, cant remember what the readings were second time as Iv lost the print out. Any advice is welcome. Thanks
  4. Re: mk3 golf OBD port
    Pembrokeshire
    22 Post(s)
    right, the lambda reading is high so it running rich. the cat is not the problem. if the lambda reading was right then i would blame the cat, but since lambda is high, then its got too much fuel going in. first thing to do is to get a computer on it and look for any codes and look at live data. it could be the cts sensor duff and it thinks the car is cold so its bunging too much fuel in. yours sin't obd compliant, but does have full diagnostic capabilities when the right computer is used. you need vcds or a high end computer like a bosch kts or my snap on modis, but they cost thousands.
    also, the co on idle is higher than it should be.
  5. Re: mk3 golf OBD port
    Mar 2015
    Ayrshire, Scotland
    Thanks for your comments, the above readings were from its first emissions test. Prior to the second test some days later I fitted a new Lambda probe and a CTS (a known good one), and it failed again, this time on High CO reading (sorry I don't have print out from second test) and as above the CO at idle IS BELOW the max limit. Can I down load this VCDS some where (preferably free) hook up my laptop to the car and run some sort of diagnosis - or is it a specialist job that will cost more than the car is worth?, I would hate this problem to get the better of me! so any further help appreciated Thanks.
  6. Re: mk3 golf OBD port
    Mar 2015
    Ayrshire, Scotland
    thanks I shall look in to that!
  7. Re: mk3 golf OBD port
    #17
    Aug 2011
    Meath
    Try replacing the known good CTS with a known new genuine one. Those little buggers cause a lot of issues
  8. Re: mk3 golf OBD port
    #18
    Mar 2015
    Ayrshire, Scotland
    Yes, you have a point, I use the term "known good one" in that I had the same emissions issue last year and a new lambda and CTS sorted the problem, since then I changed the thermostat housing and it came with a new sensor and it was used in the first mot emissions test which failed, so I re-fitted the one from last year, but failed again. Dash board temp reads correct at 90oC, although it doesn't mean the CTS is OK, does it have to be genuine VW, or is GSF or euro car parts OK ? I feel as though we are grasping at straws here! Thanks anyway and keep the ideas coming.
  9. Re: mk3 golf OBD port
    #19
    Pembrokeshire
    22 Post(s)
    you are grasping at straws until you get it on a computer.
  10. Re: mk3 golf OBD port
    #20
    Mar 2015
    Ayrshire, Scotland
    A fair point, but can I down load VCDS from some where, hook up my laptop and run a diagnostic check as iv asked earlier? I don't have the luxury of a few grand's worth of snap on computer as you do.
  1. Question OBD port no juice
    By A4 fan in forum Golf MK5 - 2004 - 2009
    Last Post: 17-02-2015, 10:09 PM
  2. OBD Port
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-01-2010, 02:33 PM
  3. OBD port on 1996 T4 ?
    By Ali baba in forum The Commercial Range
    Last Post: 14-08-2008, 08:35 AM
  4. Obd Port
    By glen poole in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-03-2008, 04:50 PM
  5. Obd Port For Vag Com
    By anilnickypatel in forum Golf MK3 - 1993 - 1999
    Last Post: 15-11-2007, 10:34 PM
